Legacy META commands - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Official File Specifications/Standards (https://forums.ldraw.org/forum-32.html) +--- Thread: Legacy META commands (/thread-24092.html) |
Legacy META commands - Orion Pobursky - 2020-06-15 I'd like to amend the File Format regarding META commands used pretty much only by the original LDraw.exe. Proposal: Add the following paragraph after the first paragraph (Beginning "Meta commands (or meta statements...") in the "META Command" section: Quote:The META commands WRITE, PRINT, CLEAR, PAUSE, and SAVE are documented here for legacy purposes only and implementation in new LDraw compliant programs is optional. RE: Legacy META commands - Roland Melkert - 2020-06-16 (2020-06-15, 0:04)Orion Pobursky Wrote: I'd like to amend the File Format regarding META commands used pretty much only by the original LDraw.exe.Seems like a good addition to me. |
