[LDView] LDView 4.4 Alpha 6 test release - Printable Version
+--- Thread: [LDView] LDView 4.4 Alpha 6 test release (/thread-24091.html)
Pages: 1 2 3
RE: LDView 4.4 Alpha 6 test release - Travis Cobbs - 2020-06-18
Not sure if anyone is interested, but I found an online tool that lets you preview html files checked into GitHub. So here is a link to the LDView 4.4 Alpha 6 Change History (the same file that is distributed with the release):
https://htmlpreview.github.io/?https://github.com/tcobbs/ldview/blob/v4.4_Alpha6/ChangeHistory.html
RE: LDView 4.4 Alpha 6 test release - Philippe Hurbain - 2020-06-19
Wondering... would it make sense to add some form of primitive substitution to lores 8\primitives? They would - for example - get higher number of sides, half of what normal primitives get?
RE: LDView 4.4 Alpha 6 test release - Steve J. - 2020-06-19
(2020-06-14, 23:57)Travis Cobbs Wrote: I have posted a test release for LDView 4.4 Alpha 6 to GitHub:
https://github.com/tcobbs/ldview/releases/tag/v4.4_Alpha6
This release does have some known issues, but it also has quite a bit of new functionality, as well as some significant bug fixes.
Right now, I have only provided installers for macOS and 64-bit Windows. If you would like me to create an installer other than one of those two, please let me know.
The ChangeHistory.html file that is included in the release lists all of the changes. In the macOS version, ChangeHistory.html is in the dmg. In the Windows version, ChangeHistory.html gets installed to wherever you install LDView (C:\Program Files\LDView by default). I think the most important changes are:
  1. Support for SPHERICAL and CYLINDRICAL texture maps.
  2. Support for !DATA meta-command for embedding texture maps into MPDs.
  3. Support for DPI scaling (AKA High DPI) on Windows, as well as Retina displays on macOS.
  4. Support for macOS Finder thumbnail generation (toggle on LDraw tab of preferences).
  5. Support for macOS Dark Mode.
  6. Multiple important TEXMAP bug fixes.
Requesting installer for Linux...  I have been using Ubuntu (16.04) 64 bit .deb up to this point on Linux Mint 19.x (Debian, Ubuntu 18.04 LTS) and Mint 18.x prior.  I have had to manually pull in one or two dependencies to make it work on Mint 19.x, but it does and beats rolling the dice with WINE.  Thanks for the continuing work.
RE: LDView 4.4 Alpha 6 test release - Travis Cobbs - 2020-06-20
(2020-06-19, 14:10)Steve J. Wrote: Requesting installer for Linux...  I have been using Ubuntu (16.04) 64 bit .deb up to this point on Linux Mint 19.x (Debian, Ubuntu 18.04 LTS) and Mint 18.x prior.  I have had to manually pull in one or two dependencies to make it work on Mint 19.x, but it does and beats rolling the dice with WINE.  Thanks for the continuing work.
Various Linux installers were added after my initial post. Does one of them work?
(2020-06-19, 6:26)Philippe Hurbain Wrote: Wondering... would it make sense to add some form of primitive substitution to lores 8\primitives? They would - for example - get higher number of sides, half of what normal primitives get?
Maybe. My existing substitution for 48 primitives simply forces them to have at least 48 segments. (So, if you set the curve quality on a notch for 48 or more segments, they end up with the same number of segments as the standard primitives.) I could in theory support 8\ primitives so that they always have half as many as the others. Unfortunately, it would be a huge number of small changes to my code base (at least 270), which would be a royal pain.
RE: LDView 4.4 Alpha 6 test release - Steve J. - 2020-06-23
(2020-06-20, 2:04)Travis Cobbs Wrote: Various Linux installers were added after my initial post. Does one of them work?
I tried the ldview-qt5-4.4a6-ubuntu-20.04.amd64.deb on Mint 19.3.  There were some dependencies not present (2?) and installed packages not meeting version requirements (1?).  I realize the generic nature of that statement does not help, but in the process of trying to satisfy individual dependencies manually I have busted my system to the point where it is stuck in a boot loop.  I think it had something to do with the libgcc/libqt5 packages.  I did a sudo apt-get install -f, followed by a sudo apt autoremove and it went down the drain from there.  I think the latter inadvertently wiped out something required for the greeter/x-session since it thought it was no longer needed.
I'll venture to guess that you were building specifically to recently released Ubuntu 20.04 LTS to stay ahead of the curve and all of those dependencies are met in that environment.  Mint 20.x hasn't quite hit the street clear of beta yet, should within the next week or so based on reports.  I'll try again then.  I was willing to take the gamble because I got the 16.04 build(s) to work in the 18.04 environment without destroying anything, but in hindsight I should have known that backwards compatibility from the future was no guarantee as opposed to better luck with old builds going into future releases.  Oh well...  (Where did I put that backup image?)
RE: LDView 4.4 Alpha 6 test release - Roland Melkert - 2020-06-23
(2020-06-23, 15:59)Steve J. Wrote: I'll venture to guess that you were building specifically to recently released Ubuntu 20.04 LTS to stay ahead of the curve and all of those dependencies are met in that environment.  Mint 20.x hasn't quite hit the street clear of beta yet, should within the next week or so based on reports.  I'll try again then.  I was willing to take the gamble because I got the 16.04 build(s) to work in the 18.04 environment without destroying anything, but in hindsight I should have known that backwards compatibility from the future was no guarantee as opposed to better luck with old builds going into future releases.  Oh well...  (Where did I put that backup image?)
I've found that building on Debian results in the best / widest compatibility as most of the other popular distributions are forks of it in one way or another.
I also use static linking as much as possible / permitted by licenses etc to increase LDCad's generic binary usability.
Just my 2cts
RE: LDView 4.4 Alpha 6 test release - Peter Bartfai - 2020-06-25
(2020-06-23, 15:59)Steve J. Wrote: I tried the ldview-qt5-4.4a6-ubuntu-20.04.amd64.deb on Mint 19.3.  There were some dependencies not present (2?) and installed packages not meeting version requirements (1?).  I realize the generic nature of that statement does not help, but in the process of trying to satisfy individual dependencies manually I have busted my system to the point where it is stuck in a boot loop.  I think it had something to do with the libgcc/libqt5 packages.  I did a sudo apt-get install -f, followed by a sudo apt autoremove and it went down the drain from there.  I think the latter inadvertently wiped out something required for the greeter/x-session since it thought it was no longer needed.
Added LinuxMint 19.3 binaries to GitHub release. Please give it a try:
https://github.com/tcobbs/ldview/releases/download/v4.4_Alpha6/ldview-4.4a6-linuxmint-19.3.amd64.deb
https://github.com/tcobbs/ldview/releases/download/v4.4_Alpha6/ldview-osmesa-4.4a6-linuxmint-19.3.amd64.deb
RE: LDView 4.4 Alpha 6 test release - Steve J. - 2020-07-06
(2020-06-25, 8:15)Peter Bartfai Wrote: Added LinuxMint 19.3 binaries to GitHub release. Please give it a try:
Thanks, will do.  (What's the difference, if any, between the two?)  In the meantime, I wanted to report that the ldview-qt5-4.4a6-ubuntu-20.04.amd64.deb installs/works on Linux Mint 20 - no complaints from package manager, no need to run sudo apt-get install -f.
RE: LDView 4.4 Alpha 6 test release - Travis Cobbs - 2020-07-06
(2020-07-06, 14:47)Steve J. Wrote: Thanks, will do.  (What's the difference, if any, between the two?)  In the meantime, I wanted to report that the ldview-qt5-4.4a6-ubuntu-20.04.amd64.deb installs/works on Linux Mint 20 - no complaints from package manager, no need to run sudo apt-get install -f.
The osmesa version is the command line-only version that is used purely for generating images.
