LDCad Set PBG generator - Printable Version
+--- Thread: LDCad Set PBG generator (/thread-24060.html)
Pages: 1 2 3 4 5
RE: LDCad Set PBG generator - Orion Pobursky - 2020-06-11
(2020-06-11, 18:09)Marc Giraudet Wrote: Found a problem with 298c02 part :
For example set 76042-1 or 7236-1 have 2 of it but in the export there are only 1x4592 +1x4593.
That is indeed a bug but not a serious one. The cross ref code doesn't take quantity into account but LDCad doesn't do anything with quantity at the moment so it shouldn't affect the ability to use the PBG effectively. I'll push a change shortly.
(2020-06-11, 18:09)Marc Giraudet Wrote: When 298c02 is exported in 2 sub parts (i prefer this solution), why 2429c01 is not ?
This is because the two parts of 2429c01 never come as different colors. Therefore it is trivial to add the part to the model and then inline it.
RE: LDCad Set PBG generator - Marc Giraudet - 2020-06-11
(2020-06-11, 18:19)Orion Pobursky Wrote: That is indeed a bug but not a serious one. The cross ref code doesn't take quantity into account but LDCad doesn't do anything with quantity at the moment so it shouldn't affect the ability to use the PBG effectively. I'll push a change shortly.
I agree it's not a serious one.
About quantity in LDCad, I use 2 part bin to check inventory of official model after finishing. I found the issue when I check my latest set (76042).
Today I check one by one but maybe LDCad could proposed further an automatic check. Or a new part bin "dynamic" like a box, the number of part decreased when you put a part in the model (at the end, easier to found parts).
Thanks for the explaination of the colour.
RE: LDCad Set PBG generator - Orion Pobursky - 2020-06-13
This bug is fixed.
Added a new feature:
If a sticker sheet that isn't in the cross reference is detected, it is skipped and a warning issued.
RE: LDCad Set PBG generator - Marc Giraudet - 2020-06-26
(2020-06-13, 3:05)Orion Pobursky Wrote: Added a new feature:
LDCad Set PBG generator broken ?
Error : {"error":"Error: cross reference file not found","messages":null,"pbg":null}
RE: LDCad Set PBG generator - Orion Pobursky - 2020-06-26
(2020-06-26, 16:40)Marc Giraudet Wrote: LDCad Set PBG generator broken ?
Fixed. I moved some code around and forgot to update the paths.
RE: LDCad Set PBG generator - Philippe Hurbain - 2020-11-02
I tested the PBG generator for the Black Seas Barracuda... Got some glitches Smile
- Some possible X-ref improvements:
970e02 -> 84637c01
2529pb01 -> 2528p30
2559c03 -> 2559c01
2557c03 -> 2557c01
3934a -> 3934?
3660 -> 3660a
42009 -> 42009a
973c11 -> torso+arms+hands? or 973c01 ?
More annoying:
4589 cone was replaced by stickers 004589
4315 hinge was replaced by stickers 004315
RE: LDCad Set PBG generator - Orion Pobursky - 2020-11-02
(2020-11-02, 15:53)Philippe Hurbain Wrote: I tested the PBG generator for the Black Seas Barracuda... Got some glitches Smile
970e02 -> 84637c01
2529pb01 -> 2528p30
2559c03 -> 2559c01
2557c03 -> 2557c01
3934a -> 3934?
3660 -> 3660a
42009 -> 42009a
More annoying:
Some of these are indeed problems with PBG gen. The rest are Rebrickable database errors which I can submit fixes. I'll have a more detail response once I have access to my desktop.
RE: LDCad Set PBG generator - Orion Pobursky - 2020-11-05
Quick update:
Quote:970e02 -> 84637c01
2559c03 -> 2559c01
2557c03 -> 2557c01
Change requests have been submitted for these
Quote:3934a -> 3934?
3660 -> 3660a
These need to be researched and a "better" LDraw to Rebrickable map created. Then I can submit change requests.
Quote:42009 -> 42009a
2529pb01 -> 2528p30
I can't find either of these
Quote:973c11 -> torso+arms+hands? or 973c01 ?
I'll add this to the crossref
Still investigating these 2
RE: LDCad Set PBG generator - Philippe Hurbain - 2020-11-05
Quote:
Quote:
42009 -> 42009a
2529pb01 -> 2528p30
Sorry, typos... was 4209 -> 4209a
and 2528pb01 -> 2528p30
I submitted a change request for both
