[Complete] Part 14396c01 (or 14379) - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: [Complete] Part 14396c01 (or 14379) (/thread-23970.html) |
Part 14396c01 (or 14379) - Orion Pobursky - 2020-04-09 I thought I saw this already, I thought wrong. I don't have this part and can't find it on digitalbricks so don't know if it's an assembly or not. Also, I get 14396 from some sources and 14379 from others. There are 4 printed versions: 3 gingerbread people and the Clock King from collectible minifig series. https://rebrickable.com/parts/14379/minifig-head-special-gingerbread-man-plain/ https://www.bricklink.com/v2/catalog/catalogitem.page?P=14396c01pb02#T=C&C=7 RE: Part 14396c01 (or 14379) - Orion Pobursky - 2020-04-09 After a little research: if it isn’t an assembly, it is, at the very least, a dual mold. RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-09 (2020-04-09, 21:44)Orion Pobursky Wrote: I thought I saw this already, I thought wrong. I don't have this part and can't find it on digitalbricks so don't know if it's an assembly or not. Also, I get 14396 from some sources and 14379 from others. There are 4 printed versions: 3 gingerbread people and the Clock King from collectible minifig series. I remembered seeing it as well, and finally I found it! The last digits are swapped (14397) ![]() I got two of them RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-26 I am working on the basic shape Pretty much through them These are basically two parts snapped together. WIth some force you can get them apart (without destruction!!!) The Sandwich part is 14396 The Filling is 13733, glad it has it's number printed. Also interesting, this is the first part I have seen where the LEGO logo is not printed straight, it is embossed as an arch...Never seen that... Done! RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-26 How do we number those faces? So we've got 14396 and the filling 13733. Patterned is 14369 -> 14369pxx The assembly then 14369c01pxx or 14369pxxc01? Or do we use the rebrickable number 14379pxx? RE: Part 14396c01 (or 14379) - Orion Pobursky - 2020-04-26 (2020-04-26, 21:39)Gerald Lasser Wrote: How do we number those faces? I'd say use BrickLink's number. And it should be pxxc01. RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-27 (2020-04-26, 23:21)Orion Pobursky Wrote: I'd say use BrickLink's number. And it should be pxxc01. Would that allow the PT to generate a "Pattern Overview" page? RE: Part 14396c01 (or 14379) - Magnus Forsberg - 2020-04-27 (2020-04-26, 23:21)Orion Pobursky Wrote: I'd say use BrickLink's number. And it should be pxxc01. No, I think that's wrong. This assembly is known as 14397 in LDD and we usually pick that number. Bricklink use 14396c01 Rebrickable use 14397pr001. I think 14379 is a typo at Rebrickable Brickset have 14398 on one of the pattern designs, the first gingerbread man from the CMF. RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-27 (2020-04-27, 6:47)Magnus Forsberg Wrote: No, I think that's wrong. This assembly is known as 14397 in LDD and we usually pick that number. To reduce clutter what do you think of: The "Sandwich" 14396:
RE: Part 14396c01 (or 14379) - Magnus Forsberg - 2020-04-27 Yes, it looks about right to me. I think we will have a similar situation on the printed dual-moulded minifig arms and legs. One of the "halves" need to be used, hard-coded in a colour, like as if it is part of the "pattern". RE: Part 14396c01 (or 14379) - Orion Pobursky - 2020-04-27 Maybe this is what you're saying and I'm just a bit unclear: 14397 should have the sandwich and the filling in color 16 with no pattern 14397pXX should be the the patterned sandwich piece(s) in color 16 with the filling hard coded in the appropriate color. RE: Part 14396c01 (or 14379) - Magnus Forsberg - 2020-04-27 +1 RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-27 So, that's it then: RE: Part 14396c01 (or 14379) - Orion Pobursky - 2020-04-27 (2020-04-27, 17:19)Gerald Lasser Wrote: So, that's it then: Maybe I should stick to web admining and leave the part creation to the professionals... RE: Part 14396c01 (or 14379) - Gerald Lasser - 2020-04-27 (2020-04-27, 17:36)Orion Pobursky Wrote: Maybe I should stick to web admining and leave the part creation to the professionals... no way! I want to get also a bit deeper into this web-stuff... |
