DatHeader Error on startup - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: DatHeader Error on startup (/thread-23849.html) |
DatHeader Error on startup - Johann Eisner - 2020-01-17 Hi community When starting the latest version from DatHeader (3.0.23), I got a error message, Missing Catecory.txt. Missing.PNG (Size: 7.88 KB / Downloads: 156) After confirming the dialog box, an attempt is made to download the file. This leads to another error message. Error.PNG (Size: 7.06 KB / Downloads: 156) After confirming this dialog box,... Hinweis.PNG (Size: 9.49 KB / Downloads: 158) DatHeader runs that way too, but this Zenario comes every time it starts. Thoughts or solves? Regards Johann RE: DatHeader Error on startup - Philippe Hurbain - 2020-01-17 Dunno... I have the same category file update problem (but since I do have the file, DH doesn't fail at startup). Updating ldconfig.ldr does work fine. Attached my category.txt file, to be placed in DH folder. RE: DatHeader Error on startup - Orion Pobursky - 2020-01-17 (2020-01-17, 16:31)Johann Eisner Wrote: Hi community There should be a category.txt file in the directory with DatHeader. Copy this file to the ldraw directory. This should solve the problem. RE: DatHeader Error on startup - Johann Eisner - 2020-01-17 Thanks Philo, Thanks Orion There is even the catecory.txt file in the ldraw root directory. It seems that the newer version (3.0.23) looks in its own root directory. 3.0.22 should access the file in the ldraw directory, which starts without problems if the file is missing in the DH root directory. RE: DatHeader Error on startup - Magnus Forsberg - 2020-01-23 Could there be another error causing this error message? Where on the ldraw sites is the file category.txt stored? When I installed using the AIOI I got a copy of the file from 2014. And it is not up to date. Many valid categories are missing. Download category.txt - Magnus Forsberg - 2020-01-24 (2020-01-23, 22:15)Magnus Forsberg Wrote: Could there be another error causing this error message? Why do Datheader fail to download this file? Where is the file stored? RE: DatHeader Error on startup - N. W. Perry - 2020-05-14 I get the same error. I did have categories.txt that had been installed with LDPE, so I copied and renamed that file and now DATHeader is happy. However, it also keeps asking for primitivescale.txt, and feeds the same connection error when I try to download that. RE: DatHeader Error on startup - Orion Pobursky - 2020-05-14 (2020-05-14, 21:33)N. W. Perry Wrote: I get the same error. I did have categories.txt that had been installed with LDPE, so I copied and renamed that file and now DATHeader is happy. categories I think this is a result of me implementing https on ldraw.org. IT probably reads the page that lists the categories and creates a txt file for it. primitivescale is here: https://ldraw.heidemann.org/index.php?page=datheader RE: DatHeader Error on startup - Orion Pobursky - 2020-05-14 More info on how DATHeader stores things: https://forums.ldraw.org/thread-20650.html RE: DatHeader Error on startup - N. W. Perry - 2020-05-14 (2020-05-14, 21:40)Orion Pobursky Wrote: categories I think this is a result of me implementing https on ldraw.org. IT probably reads the page that lists the categories and creates a txt file for it. Heh, wouldn't you know…now that link is itself broken. (Bad certificate warning, followed by 503 error.) It was working mere hours ago. RE: DatHeader Error on startup - Orion Pobursky - 2020-05-15 (2020-05-14, 23:30)N. W. Perry Wrote: Heh, wouldn't you know…now that link is itself broken. (Bad certificate warning, followed by 503 error.) It was working mere hours ago. Works for me. If you're using Firefox try a Ctrl-Shift-R RE: DatHeader Error on startup - N. W. Perry - 2020-05-15 (2020-05-15, 0:11)Orion Pobursky Wrote: Works for me. If you're using Firefox try a Ctrl-Shift-R Seems to be back up now. Chrome took a while to recover, but I was able to grab it in Safari. I also notice I have no keywords in the official list, probably due to the same connection error? And is the full error (body) scan always so very slow? (10-15 minutes to scan a 100 Kb file?) RE: DatHeader Error on startup - Orion Pobursky - 2020-05-15 (2020-05-15, 4:18)N. W. Perry Wrote: And is the full error (body) scan always so very slow? (10-15 minutes to scan a 100 Kb file?) Yes. That 4MB fallback pattern I posted on a recent thread took all night to do on my machine. RE: DatHeader Error on startup - Michael Heidemann - 2020-11-01 (2020-01-17, 16:31)Johann Eisner Wrote: Hi community That the download does not worked might be because I had used http: instead https:. Will be fixed in the next update. cu Mikeheide RE: DatHeader Error on startup - Michael Heidemann - 2020-11-01 (2020-11-01, 16:52)Michael Heidemann Wrote: That the download does not worked might be because I had used http: instead https:. Will be fixed in the next update. No, if I change http: to https: I do not get any connection. Changed all back to http:. cu Mikeheide RE: DatHeader Error on startup - Orion Pobursky - 2020-11-02 (2020-11-01, 17:01)Michael Heidemann Wrote: No, if I change http: to https: I do not get any connection. Changed all back to http:. DATHeader and all DAT/LDR/MPD files should be excluded from forced https RE: DatHeader Error on startup - Willy Tschager - 2022-09-29 (2020-01-23, 22:15)Magnus Forsberg Wrote: Could there be another error causing this error message? I checked the AIOI and couldn't find it. Please point me to it. w. RE: DatHeader Error on startup - Willy Tschager - 2022-09-29 (2020-01-17, 16:31)Johann Eisner Wrote: Hi community This problem still persists. What makes things even worse is that I couldn't find a category.txt browsing LDraw.org: not in the library nor here https://www.ldraw.org/parts/direct-parts-access.html w. RE: DatHeader Error on startup - Michael Heidemann - 2022-11-20 (2022-09-29, 10:25)Willy Tschager Wrote: This problem still persists. What makes things even worse is that I couldn't find a category.txt browsing LDraw.org: not in the library nor here https://www.ldraw.org/parts/direct-parts-access.html In DATHeader there is the menu point "update category.txt" please use that. It still works fine also today. cu mikeheide RE: DatHeader Error on startup - Magnus Forsberg - 2022-11-20 I get this message if I try, using 3.0.24 Code: --------------------------- Translated: Request Aborted: Failed to create a secure SSL/TLS channel. RE: DatHeader Error on startup - Orion Pobursky - 2022-11-20 When I implemented ssl a few years ago, I opened the routes I knew about so that DATHeader could access them without encryption. I don't know what route DATHeader is using for category.txt so it's probably not excluded. I can do that and will once I found out the route being used but I would much prefer if DATHeader used ssl instead. RE: DatHeader Error on startup - Michael Heidemann - 2023-11-11 (2022-11-20, 19:38)Orion Pobursky Wrote: When I implemented ssl a few years ago, I opened the routes I knew about so that DATHeader could access them without encryption. I don't know what route DATHeader is using for category.txt so it's probably not excluded. I can do that and will once I found out the route being used but I would much prefer if DATHeader used ssl instead. Hi Orion, I am completely with you, but my skills in vb.net and the webclient are not that good. Until today I failed to get it to work. If there is anybody out there who can help, I would very much appreciate that. :-) cu Mikeheide |
