Time for another LDConfig update? - Printable Version
+--- Thread: Time for another LDConfig update? (/thread-23823.html)
Pages: 1 2 3 4
RE: Time for another LDConfig update? - Willy Tschager - 2020-05-02
This should comprise all new colors:
RE: Time for another LDConfig update? - N. W. Perry - 2020-05-03
I have a model that will need Rubber Medium Blue on a flex axle, which doesn't seem to be in the config.
(Official usage: https://rebrickable.com/parts/32580/hose-soft-axle-7/73/ )
RE: Time for another LDConfig update? - Magnus Forsberg - 2020-05-04
(2020-05-02, 11:34)Willy Tschager Wrote: This should comprise all new colors:
Why did you name 10351 "Glitter_Trans_Green"?   Shouldn't it be "Glitter_Trans_Bright_Green"?
Could someone please make a hi quality render using the standard brick 3003?
I want to see what the opalescent colors look like. If they have some sparkling effect at all. Neither LDView nor LDCad can show that.
It looks to me as if they both have difficulties handling the opalescent colours.
Or maybe I should ask: How do I set up POV-Ray export, in LDCad or LDView, to give me decent transparent parts?
RE: Time for another LDConfig update? - Roland Melkert - 2020-05-06
(2020-05-04, 20:40)Magnus Forsberg Wrote: Or maybe I should ask: How do I set up POV-Ray export, in LDCad or LDView, to give me decent transparent parts?
By default LDCad only supports 'normal' transparency. But if Pov-ray can do it you can modify the colors.pov file LDCad uses as an include file to get whatever you need.
I would be interested in any improvements on transparency as it has been a troublesome issue from the start for me to get 'right'.
This is how it currently renders 'out-of-the-box':
RE: Time for another LDConfig update? - Willy Tschager - 2020-05-07
(2020-05-04, 11:22)Magnus Forsberg Wrote: Why did you name 10351 "Glitter_Trans_Green"?   Shouldn't it be "Glitter_Trans_Bright_Green"?
Thanks for checking. Here's the updated chart:
RE: Time for another LDConfig update? - Magnus Forsberg - 2020-05-07
(2020-05-07, 10:23)Willy Tschager Wrote: Thanks for checking. Here's the updated chart:
It looks good.
And all you changed now was the name of the "Glitter_Trans_Bright_Green" and added "Rubber_Medium_Blue"?
I have codes ready for the Ldcfgalt file.
Here is another interesting colour, or coating.
"Her hair is Light Royal Blue [TLG]/ Bright Light Blue [BL] Mini Doll, Wig, No. 37 (6261350) and is interesting as it has iridescent ink applied as a drum lacquer coating."
From this review at New Elementary.
[Image: 34697pb01.png]
https://www.bricklink.com/catalogItemIn.asp?P=34697pb01&in=M
(2020-05-07, 12:44)Magnus Forsberg Wrote: And all you changed now was the name of the "Glitter_Trans_Bright_Green" and added "Rubber_Medium_Blue"?
Yepp. Checked also the RGB. I however find it odd that Rubber_Medium_Blue. Could also be Rubber_Dark_Azur.
RE: Time for another LDConfig update? - Willy Tschager - 2020-05-19
The updated LDConfig file is now live:
https://www.ldraw.org/article/547.html
