[LDCad] Part Snapping missing/errors - Printable Version
+--- Thread: [LDCad] Part Snapping missing/errors (/thread-23807.html)
Pages: 1 2 3 4 5 6 7 8 9
RE: Part Snapping missing/errors - Jaco van der Molen - 2021-03-12
(2021-03-12, 0:57)Roland Melkert Wrote: Almost,
I woud add this to s\28192s01.dat :
0 !LDCAD SNAP_CYL [gender=F] [caps=one] [secs=S 6 4] [pos=0 8 0]
0 !LDCAD SNAP_CYL [gender=F] [caps=one] [secs=S 6 4] [pos=0 24 -20]
Big Grin
RE: Part Snapping missing/errors - Jaco van der Molen - 2021-03-17
Dish 2x2 both 2654a.dat and 2654b.dat have no snap info.
Slope brick 45 2x1 inverted 3665a.dat has no snap info at the bottom.
RE: Part Snapping missing/errors - Stefan Frenz - 2021-03-19
Wheel 2.8x34 [] for Wheel Holding Pin (4489a.dat) does not snap into Plate 2x2 with Wheel Pin (4488.dat).
RE: Part Snapping missing/errors - Jaco van der Molen - 2021-05-20
Brick  2 x  2 with Ball Socket Type X and Axlehole
57910 and 92013 (type 1 and 3) are both missing the snap info for the ball in the socket.
62712 (type 2) does have this.
I think you can copy the info from 62712 to both 57910 and 92013?
RE: Part Snapping missing/errors - Roland Melkert - 2021-05-20
(2021-05-20, 10:49)Jaco van der Molen Wrote: I think you can copy the info from 62712 to both 57910 and 92013?
I added:
0 !LDCAD SNAP_CLEAR [ID=axle]
0 !LDCAD SNAP_CYL [gender=F] [caps=none] [secs=R 6 8  A 6 16] [pos=0 24 0]
0 !LDCAD MIRROR_INFO [baseFlip=Z] [counterPart=self]
to all three, and variations of:
0 !LDCAD SNAP_CYL [gender=F] [caps=none] [secs=R 6 5] [pos=40 10 11.5] [ori=1 0 0 0 0 1 0 -1 0]
0 !LDCAD SNAP_GEN [group=techBallJnt] [gender=F] [bounding=sph 12.7] [match=size] [placement=free] [pos=40 10 0] [mirror=none]
The half socket subparts.
RE: Part Snapping missing/errors - Jaco van der Molen - 2021-05-21
(2021-05-20, 20:00)Roland Melkert Wrote: I added:
Thanks!
Is the shadow updated?
http://www.melkert.net/action/download/shadow.sf
RE: Part Snapping missing/errors - Jaco van der Molen - 2021-08-24
41682 Bracket 2 x 2 with 1 x 2 Vertical Studs does not snap at the bottom of the 1x2 plate.
