[LDCad] Part Snapping missing/errors - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: [LDCad] Part Snapping missing/errors (/thread-23807.html) |
RE: Part Snapping missing/errors - Florent Faramond - 2023-07-11 Hello Roland, I don't have permission to push on the git as recommended in the CONTRIBUTING.md. Can you give me the permission or is there another way? RE: Part Snapping missing/errors - Roland Melkert - 2023-07-11 (2023-07-11, 7:10)Florent Faramond Wrote: I don't have permission to push on the git as recommended in the CONTRIBUTING.md. The contributing.md file wasn't really supposed to be part of github yet, as it is a work in progress (references the unreleased 1.7 Beta version etc). I just forgot to uncheck it when pushing one of the other updates. Anyhow it talks about cloning the repository, but this should be forking when you want to contribute. I uploaded a newer version. RE: Part Snapping missing/errors - N. W. Perry - 2024-01-15 Bottom snap info is wrong on the 1x2 hinge parts 2429 and 2430 (was the origin moved recently or something?). 2429 should be: Code: 0 !LDCAD SNAP_CYL [gender=F] [caps=one] [secs=S 6 4] [pos=-20 8 10] [grid=C 2 1 20 0] 2430 should be: Code: 0 !LDCAD SNAP_CYL [gender=F] [caps=one] [secs=S 6 4] [pos=20 8 10] [grid=C 2 1 20 0] Also, part 60594 needs: Code: 0 !LDCAD SNAP_FGR [genderOfs=F] [seq=60] [radius=2] [pos=-34 34 2] RE: Part Snapping missing/errors - Roland Melkert - 2024-01-16 (2024-01-15, 20:31)N. W. Perry Wrote: Bottom snap info is wrong on the 1x2 hinge parts 2429 and 2430 (was the origin moved recently or something?).Apparently I missed these errors while mass removing some INCLUDE meta's I will correct this in the next GITHUB update RE: Part Snapping missing/errors - Jaco van der Molen - 2024-03-11 (2024-01-16, 20:03)Roland Melkert Wrote: Apparently I missed these errors while mass removing some INCLUDE meta's Is https://github.com/RolandMelkert/LDCadShadowLibrary/ still up and running? I see last change is about 5 months ago? RE: Part Snapping missing/errors - Roland Melkert - 2024-03-15 (2024-03-11, 14:38)Jaco van der Molen Wrote: Is https://github.com/RolandMelkert/LDCadShadowLibrary/ still up and running? Unless github has shutsdown it should still be there I haven't done much with shadow information myself lately, I will pick it up at some point though. I'm still hoping others will contribute too, as the LDraw library releases seem to be every other week these days RE: Part Snapping missing/errors - Jaco van der Molen - 2024-03-16 (2024-03-15, 21:37)Roland Melkert Wrote: Unless github has shutsdown it should still be there OK, great. I very much like to contributes, but it still unclear to me how. I know how to add snap info, but building the right header and submitting to Github is also unclear. (sorry) Can you or someone make a clear instruction on how the header should be and make a little guide how to push (?) to Github |
