Part 6135 (palm tree/Technic horn) - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Part 6135 (palm tree/Technic horn) (/thread-23787.html) |
Part 6135 (palm tree/Technic horn) - N. W. Perry - 2019-12-14 I noticed something's up with 6135.dat—it should fit all the way onto a Technic axle pin (see for example set 8880), but the axle hole isn't deep enough—only 16 LDU, but should be a full stud. Unfortunately I don't have this part in real life, so I'm not sure how it would have to be adjusted, but it's clearly not as simple as just extending the axle hole. RE: Part 6135 (palm tree/Technic horn) - Philippe Hurbain - 2019-12-14 (2019-12-14, 4:53)N. W. Perry Wrote: I noticed something's up with 6135.dat—it should fit all the way onto a Technic axle pin (see for example set 8880), but the axle hole isn't deep enough—only 16 LDU, but should be a full stud.You are painfully right... the stud is misplaced too
RE: Part 6135 (palm tree/Technic horn) - Magnus Forsberg - 2019-12-14 There's at least five different designs of this part. https://www.bricklink.com/v2/catalog/catalogitem.page?P=2536a#T=C ![]() This picture show only four, but there is also 2536e at Bricklink. So maybe one of them looks like this and is correct? And how about that partnumber, 2536? Where does it come from? RE: Part 6135 (palm tree/Technic horn) - Philippe Hurbain - 2019-12-14 Quote:This picture show only four, but there is also 2536e at Bricklink.I have version a/b/d (edit: and c too). Basic geometry looks exactly the same except for longer base. I try to improve that. Quote:And how about that partnumber, 2536? Where does it come from?2536 PALM TRUNK 6135 PALM TRUNK W. CROSS RE: Part 6135 (palm tree/Technic horn) - Philippe Hurbain - 2019-12-15 Corrected shapes are now on PT: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/2536a.dat https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/2536b.dat https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/6135a.dat https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/6135b.dat https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/2563a.dat Initial parts are to be obsoletized... For the curious: two stacked round plates on stud fill exactly the top cavity. RE: Part 6135 (palm tree/Technic horn) - Magnus Forsberg - 2019-12-15 Why two links to the same file, 2563a ? How does this affect the complete palm shortcut? https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/2518c01.dat Are you still working on the fifth version 2536e? Or is that one simply a "smoother" version of 2536a? https://www.bricklink.com/v2/catalog/catalogitem.page?P=2536e#T=C I don't think it is. Looks like the stud indentations are flat. RE: Part 6135 (palm tree/Technic horn) - Philippe Hurbain - 2019-12-15 (2019-12-15, 10:12)Magnus Forsberg Wrote: Why two links to the same file, 2563a ?Because I messed up between 2536 and 2563 Quote:How does this affect the complete palm shortcut?Geometry change doesn't affect tree shape, but indeed the shortcut should refer to the new parts, not the obsoletized one. Quote:Are you still working on the fifth version 2536e? Or is that one simply a "smoother" version of 2536a?No I don't, don't have the part and I don't have enough photo material... RE: Part 6135 (palm tree/Technic horn) - N. W. Perry - 2019-12-16 (2019-12-15, 7:43)Philippe Hurbain Wrote: Corrected shapes are now on PT: And now it fits! |
