Problem with perspective in LPub3D - Printable Version
+--- Thread: Problem with perspective in LPub3D (/thread-23725.html)
Pages: 1 2
RE: Problem with perspective in LPub3D - Johann Eisner - 2019-10-31
(2019-10-30, 22:57)Stefan Weinert Wrote: Hello Trevor,
it does not work for me unfortunately. See the attachment. LDView is on "perspective", i have played through all extreme (0.1 ... 90). even with "<>" and without.
Best regards
Stefan
Hi Stefan
I opened a Ticket on Github #378.
Problem should be solved with the next release 2.3.14.
RE: Problem with perspective in LPub3D - Trevor Sandy - 2019-10-31
(2019-10-31, 7:48)Johann Eisner Wrote: Hi Stefan
I forgot to mention that it is also necessary to set "Apply Camera Angles" to Renderer. As LPub3D is rotating the model before calling the renderer, there is no difference when the projection is changed.
[attachment=4151]
Nevertheless, this setting will not address all the unexpected behaviour. You are likely to generate an empty page because of the LPub3D calculated camera distance.
This behaviour has been corrected - See GitHub ticket #378 for the latest status.
Cheers,
RE: Problem with perspective in LPub3D - Stefan Weinert - 2019-10-31
(2019-10-31, 12:45)Trevor Sandy Wrote: I forgot to mention that it is also necessary to set "Apply Camera Angles" to Renderer. As LPub3D is rotating the model before calling the renderer, there is no difference when the projection is changed.
Cheers,
Hello Trevor,
many Thanks for your help! I will try your workaround in ticket 378!
Kind regards
Stefan
(2019-10-31, 16:14)Stefan Weinert Wrote: Hello Trevor,
Kind regards
Stefan
Hello Trevor,
have the steps from ticket # 378 performed, so the two !LPUB-lines inserted. when I clicked "Reset Page Image Cache", only the error message came up (see appendix). could only end the program with the taskmanager. have I missed a step?
