Some questions about LDCad and LPub3D - Printable Version
+--- Thread: Some questions about LDCad and LPub3D (/thread-23600.html)
Pages: 1 2
RE: Some questions about LDCad and LPub3D - Trevor Sandy - 2019-08-08
(2019-08-08, 12:18)Trevor Sandy Wrote: Hmm, thanks for reporting this behaviour. I'll take a look.
I am not able to reproduce this behaviour and no one else has reported the same. Here is what I get with the attached LDCad generated flex subfile.
[attachment=3941]
Perhaps there is some nuance I am not replicating. If you want you can share the model file that's producing this behaviour and I'll take a look.
Cheers,
RE: Some questions about LDCad and LPub3D - Trevor Sandy - 2019-08-09
(2019-08-08, 11:38)Anto Wrote: ...I have sent you an e-mail about the placement problem (finally only one page on the whole instructions).
See below the "Before" and "After" meta command corrections. Explanation notes are captured as model file comments.
Before:
[attachment=3944]
[attachment=3945]
After:
[attachment=3946]
[attachment=3947]
Cheers,
RE: Some questions about LDCad and LPub3D - Anto - 2019-08-09
Thank you for everything!
About the bug of the substitution of a sub-model, you can try with the file I sent you. Go to the page 85 for example where there is a sub-model of a flex, and try to do Right click / Substitute on the bent flex in the PLI (you can also try with a motor page 2). If you don't have any problem, perhaps it's something wrong with my computer / installation of the software and the LDraw library.
