OMR Model Render - Printable Version
+--- Thread: OMR Model Render (/thread-23557.html)
Pages: 1 2 3 4 5 6
RE: OMR Model Render - Orion Pobursky - 2019-09-04
(2019-09-04, 7:31)Lasse Deleuran Wrote: A progress bar would be a great idea, but my attempts to create one have failed as it has decreased the loading speed significantly. I will have to check StackOverflow for some pointers.
The 'Feet' issue might be due to the debth buffer issue mentioned earlier. I have also observed it with other large models which are not on wheels.
How is the general feeling of prioritization? Right now my list is:
1) Fix rendering issues (this includes what you mention here, but also the UV calculation as you can see there are still many warnings generated in the log)
2) Stud logos (while studs can easily be enabled by setting a parameter, my experience is that the file size doubles and rendering time doubles as well. I am working on a light-weight alternative)
3) Control buttons to set up camera, lights, etc.
4) Progress bar
5) Better support of transparency.
6) Support of illumination parts (such as glow-in-the-dark ghosts, etc.)
7) Distance-based blur for a more realistic rendering
8) Textures
9) Geometry culling (such as removing studs that cannot be seen)
And of course, everyone is welcome to take up a task and create pull requests - it is all open source / license free
This thread is getting unwieldy. I'm going to start a new one.
RE: OMR Model Render - Lasse Deleuran - 2019-12-06
I have pushed a new commit to the source code which speeds up rendering time significantly for older hardware by not generating textures, but rather load them asynchronously as images.
Rendering transparent parts using a custom shader still fails spectacularly.
[Image: yVgBKsj.png]
There are multiple issues here.
One is of precision. I am writing depths in pixel colors, which is far from ideal when there are multiple layers of faces hitting the same pixel.
Another issue is the stud and anti-stud geometries. For obvious reasons we do not have the disc on the bottom of a stud. However. This asymmetry causes the renderer to think the missing geometry should be rendered completely light or dark, depending on wether the missing geometry is facing toward or away from the camera.
Still. The biggest issue is with precision an transferring enough data to perform direct volumetric rendering:
[Image: QOnHPkQ.png]
Many days have gone studying and testing... many more are to be spent.
But imagine if we suddenly had realistic transparent LEGO part rendering without raytracing... it would be a game changer!
RE: OMR Model Render - Lasse Deleuran - 2019-12-26
I have added dat.GUI to set up the scene - see sample_physical.htm and call "scene.setUpGui()".
With this, I would like to revisit the state of the physical renderer:
  1. Fix rendering issues This seems to be at a tolerable level. Right now the largest issues seem to come from line 2's partially overlapping line 5's.
  2. Stud logos DONE using textures
  3. Control buttons to set up camera, lights, etc. DONE using dat.GUI
  4. Progress bar DONE using animated construction
  5. Better support of transparency. WIP. From my prodding in the rendering communities, this seems to be very hard, and perhaps worthy of a research paper if I can create real-time realistic rendering of transparent elements
  6. Support of illumination parts (such as glow-in-the-dark ghosts, etc.) MISSING
  7. Distance-based blur for a more realistic rendering MISSING
  8. Textures DONE: All 3 types of projection, as well as inline textures. Only issue is clamping where the standard clamping from three.js materials stretches textures to edges.
  9. Geometry culling (such as removing studs that cannot be seen) WIP I am looking into the use of InstancedMesh for quicker rendering using less ressources.
I am currently looking into performance optimizations, such as #9 on the list. What is the general feeling for the readiness of this code base? Are there aspects you would like to see me improve further before proposing a release?
RE: OMR Model Render - Lasse Deleuran - 2020-05-27
With inline textures now being officially part of the standard (see https://forums.ldraw.org/thread-24058.html ), I have removed the warning when using them.
The next improvement will likely be to include glow-in-dark effect for those parts as a recent development gave me a nice and somewhat easy way of getting this implemented.
Are there other issues that you would like to see fixed for OMR rendering?
RE: OMR Model Render - Roland Melkert - 2020-05-27
(2020-05-27, 12:23)Lasse Deleuran Wrote: With inline textures now being officially part of the standard (see https://forums.ldraw.org/thread-24058.html ), I have removed the warning when using them.
Are there already models actually using !DATA in the omr?
I seem to remember you experimenting with this, but I believe it used one of the older versions of the proposal (the one with 'sub-subfiles').
Or maybe the better question is: are there currently any models in the OMR which depend on unofficial textured parts?
RE: OMR Model Render - N. W. Perry - 2020-05-27
(2020-05-27, 22:38)Roland Melkert Wrote: Are there already models actually using !DATA in the omr?
One of mine does, at least: https://forums.ldraw.org/thread-7689-post-35244.html#pid35244
RE: OMR Model Render - Lasse Deleuran - 2020-05-28
Yes, I started implementing it back when the proposed standard said "0 FILE... 0 !DATA START" and since I uploaded some files between then and now, the latest version of the code is now able to parse both of these as well as the Studio version of inlined textures.
Output can be either to this latest LDraw format version or to Studio. See This model as an example:
[Image: 583.png]
When pressing "Download" the OMR version refers to the stickers as separate parts. These can be downloaded in the table below in either "LDraw" or "Studio" versions. The LDraw versions are structured as follows:
0 FILE sticker_30342_1.dat
0 Sticker 1 for 30342
0 Name: sticker_30342_1.dat
0 Author: Sticker Builder
0 !TEXMAP START PLANAR -8 0.5 -39 -8 0.5 39 8 0.5 -39 sticker_30342_1.dat.png
0 !: 3 16 8 0 -39 8 0 39 -8 0 39
0 !: 3 16 8 0 -39 -8 0 39 -8 0 -39
0 !TEXMAP END
1 16 0 0 0 8 0 0 0 0.5 0 0 0 39 box5.dat
0 !: iVBORw0KGgoAAAANSUhEUgAAAQAAAABACAIAAAB6Pz7pAAAAAXNSR0IArs4c6QAAAARnQU1BAACx
0 !: jwv8YQUAAAAJcEhZcwAAEnQAABJ0Ad5mH3gAACRfSURBVHhe7X1ZrCXXdd3ZZ6jpjm/s1wO7m5M4
I will update some of the stickers to not use Texmap before I submit this model.
RE: OMR Model Render - Orion Pobursky - 2020-05-28
There's nothing on my end other than time to modify and test the OMR to use buildlinginstructions.js instead of brigl.
I'm gonna try to include the option to have either the instructions style render or the photoreal render. That's not an issue with your code.
(2020-05-28, 18:21)Orion Pobursky Wrote: There's nothing on my end other than time to modify and test the OMR to use buildlinginstructions.js instead of brigl.
Alright. The switch between the two renderers is just matter of setting the option "physicalRenderingAge" to 0 or 1 as seen in sample_physical.htm and sample_view.htm, respectively.
