Stickers for set 10266 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Stickers for set 10266 (/thread-23539.html) |
Stickers for set 10266 - Jaco van der Molen - 2019-07-08 Hi all, I am making progress in creating the stickers for set 10266 (the Lunar Lander) But now I am totally in the dark for the partnumber. I submitted 3 simple stickers the the tracker, but apperntlythe part number is still wrong. Since I still do not own the set I am working from images of the stickersheet found online. I must have seen atleast one version that had 134071 on it somewhere, so I took that as partnumber with letter suffix, a, b, c... h, i for the sticker number. Now I found another scan of the stickersheet that has number 65305/6279911 on it. Please enlighten me on what number to use and how to name these parts? Judging Magnus' hold comment: https://www.ldraw.org/article/339.html "The part number for the flat sticker part is the SKU from the edge of the sticker sheet with a single letter suffix. Each different sticker from a single sheet should have a unique suffix. [...] Stickers from sheets with combo 5-digit/7-digit numbers should use the 7-digit number. " It must be 6279911? So sticker number 8, 9 and 13 should be 6279911h, 6279911i and 6279911m Oh, and can the parts with the wrong number be deleted please: 134071a08.dat 134071h.dat 134071i.dat 134071m.dat Or rename the last 3? RE: Stickers for set 10266 - Orion Pobursky - 2019-07-08 (2019-07-08, 13:32)Jaco van der Molen Wrote: It must be 6279911? Yes. This is the correct number. RE: Stickers for set 10266 - Orion Pobursky - 2019-07-08 (2019-07-08, 13:40)Orion Pobursky Wrote: Yes. This is the correct number. Confirmed. https://www.brothers-brick.com/2019/06/03/lego-creator-expert-10266-nasa-apollo-11-lunar-lander-review/lego-creator-expert-10266-nasa-apollo-11-lunar-lander-42/ RE: Stickers for set 10266 - Jaco van der Molen - 2019-07-08 (2019-07-08, 13:40)Orion Pobursky Wrote: Yes. This is the correct number. Ok, thanks. Can my submits be renamed? Or delete them, then I will submit correct ones. RE: Stickers for set 10266 - Magnus Forsberg - 2019-07-08 (2019-07-08, 13:49)Jaco van der Molen Wrote: Ok, thanks. Can my submits be renamed? Or delete them, then I will submit correct ones. Yes. Send a mail to [email protected] and ask for a renumbering. RE: Stickers for set 10266 - Willy Tschager - 2019-07-16 Did you email Chris for the deletion of these: parts/134071a08.dat Sticker 2.9 x 1.4 with Black and Gold Straight Planes parts/134071h.dat Sticker 2.9 x 1.9 with Black and Gold Straight Planes parts/134071i.dat Sticker 2.9 x 1.9 with Black and Gold Diagonal Planes parts/134071m.dat Sticker 3.9 x 2.9 with Black and Gold Straight and Diagonal Planes w. RE: Stickers for set 10266 - Jaco van der Molen - 2019-07-16 (2019-07-16, 4:19)Willy Tschager Wrote: Did you email Chris for the deletion of these: Yes, delete 134071a08.dat And rename the other 3 or delete them too, so I can submit the correct ones. |
