Stickers with round or sharp edges? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Stickers with round or sharp edges? (/thread-23489.html) |
Stickers with round or sharp edges? - Jaco van der Molen - 2019-06-16 Hi all, Currently, I am trying my best to create the stickers for set 10266 (Apollo 11 Lunar Lander). I do this to learn to work with LDPC and LDPE :-) Since I do not own the model (yet) I can only judge online pictures and reviews, but it is my opinion that the edges are round. Do we need to mimic this or would sharp (straight) edge be good too? Currently, some stickers have this feature in the official library. I could be mistaken, but I think most stickers in the newer sets nowadays have rounded edges whereas in the past most stickers had straight edges? If they must be round, would it be an idea to create a submodel for the bottom box, since a sticker is, in fact, a box that is 0,25 LDU thick? Attached is my first attempt at sticker nr. 5 of this set. Also, what would be the part number for the sticker or how do we name it? Jaco RE: Stickers with round or sharp edges? - Chris Dee - 2019-06-16 (2019-06-16, 19:33)Jaco van der Molen Wrote: Hi all, Official Library Specification for Sticker Parts RE: Stickers with round or sharp edges? - Philippe Hurbain - 2019-06-17 (2019-06-16, 19:33)Jaco van der Molen Wrote: If they must be round, would it be an idea to create a submodel for the bottom box, since a sticker is, in fact, a box that is 0,25 LDU thick?A submodel is useless (except if you have several stickers of the same size) as it would not scale properly with different size stickers (the rounded corners would be larger on larger stickers). ...I still think that sharp corners is OK here... RE: Stickers with round or sharp edges? - Jaco van der Molen - 2019-06-17 (2019-06-17, 5:31)Philippe Hurbain Wrote: A submodel is useless (except if you have several stickers of the same size) as it would not scale properly with different size stickers (the rounded corners would be larger on larger stickers). OK, I see. However, there are more stickers of the same size, not only in this set but many others (especially Friends). Stickers that fit tiles 1x2, 1x3, 2x2, 2x3, 2x4 are very common, are they not? Same goes for stickers for bricks 1x2, 1x3, 1x4, etc. All have round corners. But if sharp is OK, then should we decide on a standard? Also, a sticker is not exactly the size of the tile or brick it supposed to attach to. Would a margin of 1 LDU be enough for scale? So this sticker would be 38x38 LDU (to fit the surface of a 2x2 tile that is 40x40 LDU). Who can answer my other question on partnumber or name? RE: Stickers with round or sharp edges? - Willy Tschager - 2019-06-17 (2019-06-17, 5:40)Jaco van der Molen Wrote: Who can answer my other question on partnumber or name? https://www.ldraw.org/article/339.html w. RE: Stickers with round or sharp edges? - Jaco van der Molen - 2019-06-17 (2019-06-17, 5:57)Willy Tschager Wrote: https://www.ldraw.org/article/339.html OK, sorry for my ignorance. I should have known there is an article on that Thanks for pointing it out. RE: Stickers with round or sharp edges? - Max Martin Richter - 2019-06-18 (2019-06-17, 5:40)Jaco van der Molen Wrote: Also, a sticker is not exactly the size of the tile or brick it supposed to attach to. It depends on the sticker. Some of them have 38x38 LDU, others have 37x37 LDU und the next is only 36.5x36.5 LDU for a 2x2 tile. I would model them as they are. Anyway I'm fine with sharp corners. I think nobody will recognize a rounded area of sticker with 0.4 mm -> 1 LDU, when starring at a whole model. RE: Stickers with round or sharp edges? - Magnus Forsberg - 2019-06-18 (2019-06-18, 18:06)Max Martin Richter Wrote: It depends on the sticker. I would say it depends on the part the sticker should be placed at. I really don't like these two, now that the part have been reshaped. https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/54200d01.dat https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/54200d02.dat RE: Stickers with round or sharp edges? - Max Martin Richter - 2019-06-18 (2019-06-18, 18:34)Magnus Forsberg Wrote: I would say it depends on the part the sticker should be placed at. That's a good point. Never thought for this issue... RE: Stickers with round or sharp edges? - Jaco van der Molen - 2019-06-19 (2019-06-18, 18:06)Max Martin Richter Wrote: It depends on the sticker. Some of them have 38x38 LDU, others have 37x37 LDU und the next is only 36.5x36.5 LDU for a 2x2 tile. I would model them as they are. OK, so no round corners on stickers then and 1 LDU bleeding around. |
