PT Mockup - Printable Version
+--- Thread: PT Mockup (/thread-23460.html)
Pages: 1 2 3 4 5 6 7 8
RE: PT Mockup - Orion Pobursky - 2019-06-12
(2019-06-12, 13:42)Orion Pobursky Wrote: Nope. Not supporting that. Even MS is urging people to switch.
IE 11 should be fine though.
Supported;
  • Last 2 Versions FF, Chrome, Safari Mac
  • IE 11+
  • Android 4.4+, Chrome for Android 44+
  • iOS Safari 7+
  • Microsoft Edge 12+
(2019-06-12, 13:14)Orion Pobursky Wrote: Any more “oh by the ways”
Changes to ptdetail have been shipped to Chris for his final review and approval. Once that’s done, the header, menu, content, and footer will all be changed at once. The other PT output scripts (like ptactivity or ptscan) are less complex and should play well with the new markup until they can be updated (there may be some outliers but those can be fixed on “as found” basis)
RE: PT Mockup - Willy Tschager - 2019-06-12
(2019-06-12, 17:38)Orion Pobursky Wrote: Changes to ptdetail have been shipped to Chris for his final review and approval.
Thanks for all the effort you put into this.
RE: PT Mockup - Johann Eisner - 2019-06-12
I understand only half of it, but I don't have to understand everything.  The result looks really great.  Thank you.
RE: PT Mockup - Jaco van der Molen - 2019-06-13
(2019-06-12, 17:38)Orion Pobursky Wrote: Changes to ptdetail have been shipped to Chris for his final review and approval. Once that’s done, the header, menu, content, and footer will all be changed at once. The other PT output scripts (like ptactivity or ptscan) are less complex and should play well with the new markup until they can be updated (there may be some outliers but those can be fixed on “as found” basis)
Great. Looks good, better then before!
RE: PT Mockup - Orion Pobursky - 2019-06-13
So the next challenge is the patterned part summary. It’s still ok with the new header and footer markup but needs some love. I’ve put a mock-up here:
http://www.ldraw.org/pt-pattern-mockup.html
Right now it look terrible but that because it’s in an intermediate state while I play around with the markup.
RE: PT Mockup - Victor Di Rienzo - 2019-06-13
(2019-06-13, 14:43)Orion Pobursky Wrote: So the next challenge is the patterned part summary. It’s still ok with the new header and footer markup but needs some love. I’ve put a mock-up here:
Showing the thumbnails bigger in all the section of part tracker its a must.
Something i don't like is, that when you click on the image of the brick it shows you the jpg file. it should take you to the details page of that brick. also you can add a 3d preview of the brick
[Image: RTCkKl1.png]
also you can add a download link of that part. into the pt pattern page.
[Image: Zwn2pFE.png]
check the spacing between the lines of the parts they are overlapping .
[Image: HYtO825.png]
(2019-06-12, 13:45)Orion Pobursky Wrote: IE 11 should be fine though.
Supported;
  • IE 11+
  • iOS Safari 7+
2019
[Image: best-web-browser-w3.png]
All your suggestions are good. Thanks
The overlap problem is just because I’m still playing around with how to lay things out. Right now there’s a mixture of new markup and old markup and those 2 systems sometimes conflict. Rest assured there will be no overlap in the finalize product.
The biggest challenge right now is making the images appear full size without overlap in all resolutions
RE: PT Mockup - Gerald Lasser - 2019-06-13
First feedback:
  • I would remove the "Quick Look-Up", this is just the standard PT search available in the top bar (at the real PT site)
  • I would like a "Filter" instead, so that you can quickly scan the shown patterns quickly for a keyword, e.g. "Eye" the result will only shown pictures where the search matches, the others shall be greyed out/empty box
    Search might be relevant for parts with a huge number of parts (heads, tiles)
  • The part-code of an official part should link to the .dat file for download
  • As an option a "display as list" possibility to e.g. quickly and cleanly copy the data to Excel
    This should then shown Picture, PartNo, Description, PT Status
Not too much I hope for now
