Technic 1994 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Official Models (https://forums.ldraw.org/forum-17.html) +--- Thread: Technic 1994 (/thread-23330.html) |
Technic 1994 - Orion Pobursky - 2019-04-04 Topic for 1994 Technic models 8880 - Super Car - Orion Pobursky - 2019-04-04 8880 - Super Car OMR Compliant Missing: Nothing Comments: I chose this model specifically to challenge me to use LDCad fully. I consider myself challenged. RE: 8880 - Super Car - Max Martin Richter - 2019-04-04 (2019-04-04, 19:05)Orion Pobursky Wrote: <Render to follow> Well done. Btw: you modelled an earlier set with black "Technic Gear 16 Tooth with Clutch" I own a later model with the newer dark gray gears but I know at least two people owning the black version. :-) RE: 8880 - Super Car - Orion Pobursky - 2019-04-04 (2019-04-04, 19:28)Max Martin Richter Wrote: Well done. Btw: you modelled an earlier set with black "Technic Gear 16 Tooth with Clutch" Since I don’t actually own this model, I used the pbg generator on Rebrickable for the parts list RE: 8880 - Super Car - Orion Pobursky - 2019-04-04 (2019-04-04, 19:05)Orion Pobursky Wrote: <Render to follow> Also note that, due to the complex angles in the set, there is some part mismatch. Most of these gaps/overlaps are less than a couple of LDU and not super noticable. The is one large error of a little more than 4 ldu that I hid behind the headlights. RE: 8880 - Super Car - Travis Cobbs - 2019-04-05 (2019-04-04, 19:33)Orion Pobursky Wrote: Since I don’t actually own this model, I used the pbg generator on Rebrickable for the parts list I do own the set, and the one I have came with dark gray versions of the 6542 clutch gears. RE: 8880 - Super Car - Orion Pobursky - 2019-04-05 (2019-04-05, 1:29)Travis Cobbs Wrote: I do own the set, and the one I have came with dark gray versions of the 6542 clutch gears. Yah. After Max’s post, while I started on the B model, I noticed the instructions have them in dark grey as well. This is likely a mistake on Rebrickable. RE: 8880 - Super Car - Orion Pobursky - 2019-04-05 (2019-04-04, 19:05)Orion Pobursky Wrote: 8880 - Super Car I updated the model for OMR compliance, fixed a few color problems, and rotated 2 of the wheels to the proper orientation. RE: 8880 - Super Car - Max Martin Richter - 2019-04-05 (2019-04-05, 1:53)Orion Pobursky Wrote: Yah. After Max’s post, while I started on the B model, I noticed the instructions have them in dark grey as well. This is likely a mistake on Rebrickable. Nope, is written above, there is an early version with the black gears. I can't remember further differences except of these gears. RE: 8880 - Super Car - Orion Pobursky - 2019-04-05 (2019-04-05, 5:09)Max Martin Richter Wrote: Nope, is written above, there is an early version with the black gears. I can't remember further differences except of these gears. That may be but since the instructions have dark grey I changed them in addition to the other color error I noticed (tire rubber instead of black) RE: 8880 - Super Car - Orion Pobursky - 2019-04-05 (2019-04-04, 19:05)Orion Pobursky Wrote: 8880 - Super Car Update. Added most of the the stickers. Missing the one for the 4x4 tile on the front. sticker.png (Size: 19.75 KB / Downloads: 368) RE: 8880 - Super Car - Orion Pobursky - 2019-04-05 (2019-04-05, 20:58)Orion Pobursky Wrote: Update. Added most of the the stickers. Missing the one for the 4x4 tile on the front. Update to the update. Last missing sticker added. Thanks Max. RE: 8880 - Super Car - Johann Eisner - 2019-04-06 (2019-04-05, 21:31)Orion Pobursky Wrote: Update to the update. Last missing sticker added. Thanks Max. Update ~moved to files and add the model to the OMR. Thanks Orion RE: 8880 - Super Car - Orion Pobursky - 2019-04-06 (2019-04-06, 13:16)Johann Eisner Wrote: Update ~moved to files and add the model to the OMR. That’s odd. I ran it through MDPCenter. There shouldn’t have been any moved to’s 8880 - Super Car - F1 Racer (B Model) - Orion Pobursky - 2019-04-10 8880 - Super Car - F1 Racer (B Model) OMR Compliant Missing: OCTAN Sticker RE: Technic 1994 - Charles Farmer - 2019-04-14 (2019-04-04, 19:01)Orion Pobursky Wrote: Topic for 1994 Technic models I created the 6 models of 8032. This was my second set I got as a kid. Good old memories When I run MPDcenter's check on OMR compliance, it sometimes gives the message that the files are not OMR comform. However, no error is shown. If somebody can tell me what is wrong with the files, that would be appreciated . RE: Technic 1994 - Philippe Hurbain - 2019-04-14 Nice models MPDCenter chokes on the last three files because of "~Moved to" parts (parts that have been renamed in LDraw library). If you look at the quick check window, MPDcenter tells the problem: Quote:Check for: 8032 - Universal Set - Helicopter.mpd To correct: Edit -> update ~movedto references then save. Here the files were 3665 (moved to 3665a) and 4276 (moved to 4276b) RE: 8880 - Super Car - Max Martin Richter - 2019-04-14 Sorry, I found another glitch: The ends of the spoiler needs to be bent down. RE: Technic 1994 - Johann Eisner - 2019-04-14 (2019-04-14, 6:29)Philippe Hurbain Wrote: Nice models To display these errors, these two checkboxes in option ---> options must be set. RE: Technic 1994 - Charles Farmer - 2019-04-14 (2019-04-14, 9:58)Johann Eisner Wrote: To display these errors, these two checkboxes in option ---> options must be set. Thanks! I did not have that option checked, so I did not see the error. I updated the three files, so now all files are OMR compliant RE: Technic 1994 - Charles Farmer - 2019-04-15 I am trying to model all 6 variants of 8062. First one (most simple one) is finished . 8858 - Rebel Wrecker - Max Martin Richter - 2019-04-16 [color=#0072bc]Download MPD[/color] (OMR compliant) Known errors: None. Done with LDCad 1.6c RE: Technic 1994 - Charles Farmer - 2019-04-25 Here are the other five models of 8062 Their are no (missing) stickers. Everything seems OMR compliant. Everything is done with LDcad1.6b. RE: Technic 1994 - Charles Farmer - 2019-05-25 I completed the main model of set 8808. However, the stickers are still missing. Is that something I can do myself? I also never created a new part, so I am afraid that it might be too difficult for me, but I would be happy if some of you tell me otherwise. So, would it be possible for me (=no experience with new parts/stickers) to create my own sticker? And if so, are there some good tutorials to start with? Thanks in advance! RE: Technic 1994 - Willy Tschager - 2019-05-25 (2019-05-25, 3:35)Charles Farmer Wrote: However, the stickers are still missing. Is that something I can do myself? I also never created a new part, so I am afraid that it might be too difficult for me, but I would be happy if some of you tell me otherwise. This is your friend: https://sourceforge.net/projects/patterncreator/ A tutorial in French can be found here: http://jc-tchang.philohome.com/manuel/LPC.htm Google Translate should do a decent job. Once you're through with the pattern itself come back with a screenshot. w. RE: Technic 1994 - Charles Farmer - 2019-05-26 (2019-05-25, 16:22)Willy Tschager Wrote: This is your friend: Thanks! I created the pattern for one sticker (out of three). Here is a screenshot: RE: Technic 1994 - Willy Tschager - 2019-05-27 I'm impressed by the quality of the pattern and the speed you made it. I presume you measured the real sticker properly and used the corresponding LDUs as template in LDPC? This is your next friend after you exported your pattern to a dat file: http://nilsschmidt1337.github.io/ldparteditor/ There is a some sort of wiki: https://github.com/nilsschmidt1337/ldparteditor/wiki/home-backup or the French version (at this point you probably regret not doing the French class at school ;-): http://jc-tchang.philohome.com/manuel/LDPartEditor.htm Start loading some already certified sticker to learn how they look like DATwise. I know for sure you read all the relevant specs: File Format 1.0.2 Official Library Header Specification File Format Restrictions for the Official Library and most important: Official Library Specification for Sticker Parts Your last step before submitting your part to the PT is some legal stuff: LDraw.org Contributor Agreement and some more reading: The LDraw Parts Tracker We are waiting for you at the PT. w. RE: 8858 - Rebel Wrecker - Quad Bike - Max Martin Richter - 2019-11-19 [size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#0072bc]Download MPD[/font][/size][/color][size=small][font=Tahoma, Verdana, Arial, sans-serif] (OMR compliant)[/font][/size] [size=small][font=Tahoma, Verdana, Arial, sans-serif]Known errors: None.[/font][/size] [size=small][font=Tahoma, Verdana, Arial, sans-serif]Done with [/font][/size][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#0072bc]LDCad 1.6c[/font][/size][/color] 8824 - Hovercraft - Philippe Hurbain - 2019-12-21 Download MPD (OMR compliant) Known errors: Missing stickers. Done with LDCad 1.6c Rendered with Studio 2 Lets celebrate the 25th birthday of this cute little set... and the final apparition in LDraw of the angled bumper! (Thanks, Magnus ) RE: 8880 - Super Car - N. W. Perry - 2021-10-07 (2019-04-04, 19:05)Orion Pobursky Wrote: 8880 - Super Car Just came here to say, a challenge indeed, but a fun one! I built all of the first four supercars in order, so as to increase the challenge along with the progression of Technic itself. I will say, I was pleasantly surprised by this set—while there are many things to work out, they all are for the most part work-outable! There weren't any angles in the bodywork that couldn't be calculated with either the built-in triangulation tools or Roland's special right angle calc script. And surprisingly few of the inevitable overlaps because of multiple connection points; these can be mitigated using scaling if you're so inclined. All of the gears can be meshed, too—well, almost all. Because of the different gear sizes on the central steering shaft, the front and back pinions don't both mesh perfectly with the racks when the steering is at center. You can split the difference and be satisfied, but I do wonder what this feels like on the real model? All in all, I actually found 8860 harder to model, because of all the dang hoses. :-) RE: Technic 1994 - hehud - 2021-10-29 Done with LeoCad, |
