Technic 2019 - Printable Version
+--- Thread: Technic 2019 (/thread-23139.html)
Pages: 1 2 3 4
RE: Technic 2019 - N. W. Perry - 2019-11-24
(2019-11-23, 11:07)Willy Tschager Wrote: Yep! You have also to consider that not all model builders are able to author a part or sticker. In addition such projects are long runners. It took almost a year and half to get the 10246 - Detective’s Office done 'cos of a few missing parts.
Hmm, well I'm definitely stuck on authoring any complex new parts for now, but I didn't run into any great difficulty with stickers. I've used a couple of different methods, both involving Studio Part Designer. For set 5550 I applied patterns directly to the parts that are meant to receive stickers. Then I realized that a bona-fide sticker part should be its own thing, made up of a box primitive with a pattern applied to it, so I did that for the "data sheet" sticker in set 7181. (I've attached both files—would either of these be acceptable in the OMR?)
RE: Technic 2019 - Orion Pobursky - 2019-11-24
(2019-11-24, 2:09)N. W. Perry Wrote: Hmm, well I'm definitely stuck on authoring any complex new parts for now, but I didn't run into any great difficulty with stickers. I've used a couple of different methods, both involving Studio Part Designer. For set 5550 I applied patterns directly to the parts that are meant to receive stickers. Then I realized that a bona-fide sticker part should be its own thing, made up of a box primitive with a pattern applied to it, so I did that for the "data sheet" sticker in set 7181. (I've attached both files—would either of these be acceptable in the OMR?)
Attached to this post? Nothing is listed. But I did the 7181 sticker already:
https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/4141698a.dat
RE: Technic 2019 - N. W. Perry - 2019-11-25
(2019-11-24, 3:37)Orion Pobursky Wrote: Attached to this post? Nothing is listed. But I did the 7181 sticker already:
Hmm, there should have been an edit—naturally, unless I embedded my custom part, you wouldn't know whether my model was compliant, so I removed the attachments. Looking at them now, I realize I never made them cross-compatible between Studio/Part Designer and LDraw—and indeed, the sticker (or patterned) parts I have created don't appear in LDCad. So I've got more of that process to look into; perhaps then I'll realize why most modelers avoid it. :-)
RE: Technic 2019 - Roland Melkert - 2019-11-25
(2019-11-25, 17:27)N. W. Perry Wrote: Hmm, there should have been an edit—naturally, unless I embedded my custom part, you wouldn't know whether my model was compliant, so I removed the attachments. Looking at them now, I realize I never made them cross-compatible between Studio/Part Designer and LDraw—and indeed, the sticker (or patterned) parts I have created don't appear in LDCad. So I've got more of that process to look into; perhaps then I'll realize why most modelers avoid it. :-)
Far as I know studio uses it's own texture mapping extension on top of the LDraw part geometry.
So any textures will be lost when 'exporting' to LDraw.
RE: Technic 2019 - Philippe Hurbain - 2019-11-26
(2019-11-25, 22:44)Roland Melkert Wrote: Far as I know studio uses it's own texture mapping extension on top of the LDraw part geometry.
Yes, texture image is Base64 encoded in Studio exported "LDraw" part file (quotes because the  is not Ldraw compliant!). See https://forums.ldraw.org/thread-23400-post-32052.html#pid32052
42088 - Cherry Picker - Marc Belanger - 2019-12-04
Cherry Picker
Extra Building Instructions: Tow Truck
All files are OMR compliant
Done with LDCad 1.6c
Rendered with Studio 2.0
RE: 42088 - Cherry Picker - Philippe Hurbain - 2019-12-04
Looks like I forgot this model...
FYI 32905 is available on PT: https://www.ldraw.org/cgi-bin/ptdetail.cgi?s=32905
RE: 42088 - Cherry Picker - Marc Belanger - 2019-12-05
(2019-12-04, 8:27)Philippe Hurbain Wrote: FYI 32905 is available on PT: https://www.ldraw.org/cgi-bin/ptdetail.cgi?s=32905
OK, I'll need help with that. I got the part file and the required (unofficial) subfiles, which needed another part file and additionnal required (unofficial) subfiles. Crammed everything in my MPD file, ran through MPDCenter and I got the following errors :
Error in: '42088 - s\4716s02.dat' Filename should have 3 or 4 portions.
Error in: '42088 - s\4716s02.dat' Set number from MPD file name and DAT file name does not match.
Error in: '42088 - s\4716s02.dat' Filename not OMR conform because of the above error(s).
Error in: '42088 - 1-4cyloh.dat' Unofficial file 1-4cylih.dat needs to be added.
Error in: '42088 - s\4716s01.dat' Filename should have 3 or 4 portions.
Error in: '42088 - s\4716s01.dat' Set number from MPD file name and DAT file name does not match.
Error in: '42088 - s\4716s01.dat' Filename not OMR conform because of the above error(s).
Error in: '42088 - s\4716s03.dat' Filename should have 3 or 4 portions.
Error in: '42088 - s\4716s03.dat' Set number from MPD file name and DAT file name does not match.
Error in: '42088 - s\4716s03.dat' Filename not OMR conform because of the above error(s).
RE: 42088 - Cherry Picker - LDCad unofficial embedding - Philippe Hurbain - 2019-12-05
(2019-12-05, 0:02)Marc Belanger Wrote: Error in: '42088 - s\4716s03.dat' Filename not OMR conform because of the above error(s).
42088 - s\4716s03.dat should be s\42088 -4716s03.dat (and referred to as such).
Attached the model with correct embedding. I made embedding with LDCad, first removed "42088 - " prefix using file->cleanup detect. Then File -> cleanup -> Check "embed unofficial part AND add prefix -> use OMR.. button and key in 42088 set number.
Roland, would there be a way to properly embed part without removing prefix first?
And otherwise, I also got the buggy '42088 - s\4716s03.dat' when I tried to embed the wormscrew directly by right-click on it -> reorganize -> embed unofficial content -> fill in '42088 - ' as prefix. Roland, I guess this is a bug Wink
RE: 42088 - Cherry Picker - Magnus Forsberg - 2019-12-05
I'm planing to do a rework of these subfiles tonight.
