Can not submit any part since yesterday - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Help (https://forums.ldraw.org/forum-13.html) +--- Thread: Can not submit any part since yesterday (/thread-23056.html) |
Can not submit any part since yesterday - Ulrich Röder - 2018-12-04 Hello everybody, Since yesterday (03.12.2018), I am no longer able to submit parts on the tracker. The reason for this must be a UTF8 / Ansi problem because my surname contains an "umlaut" (German "Ö"). The tracker generates an automatic upload blocking: Header errors: LINE 3: Author name (Ulrich Röder) must match registered name (Ulrich Röder) for Author ID (UR) ... and that, even though all parts were stored correctly in UTF8. On my well-running system, only the update of the Nvidia driver has re-established, so this was the first suspect. But even a rollback to the previous driver brought no improvement. Also not another browser. No matter what I save ... whether DATHeader, LDDesign Pad, or LDPartEditor ..... always the same unpleasant result. Maybe there was a change on the server, unnoticed, due to the extension of png. uploads for texmap? "The error" is usually in front of the PC .... smile ... but I definitely find no clue ..... as I said ... except the driver update ... no changes on my part. ..any idea? RE: Can not submit any part since yesterday - Chris Dee - 2018-12-04 (2018-12-04, 17:50)Ulrich Röder Wrote: Hello everybody, This looks like an unwanted effect of some added checks in the change to submit.cgi - see here. I'll take a look. RE: Can not submit any part since yesterday - Chris Dee - 2018-12-04 (2018-12-04, 19:55)Chris Dee Wrote:(2018-12-04, 17:50)Ulrich Röder Wrote: Hello everybody, I think this should be fixed now. RE: Can not submit any part since yesterday - Ulrich Röder - 2018-12-04 Thanks for your efforts, Chris. but unfortunately no change as before. It's not working. Hang something helpless in the curve .. smile .... because of that. The same procedure. RE: Can not submit any part since yesterday - Ulrich Röder - 2018-12-06 Solved .... all right now! |
