Suggestion for showing process within the PT - Printable Version
+--- Thread: Suggestion for showing process within the PT (/thread-23043.html)
Pages: 1 2
RE: Suggestion for showing process within the PT - Magnus Forsberg - 2018-11-28
(2018-11-28, 10:44)Chris Dee Wrote: although I'd prefer it to be triggered by a threshold number of certified parts.
Maybe this is a way to also get more active reviewers. If we had a known trigger level that would generate a part release, we would have a common goal to work against.
I recently looked on all the files in need of a second vote. But I could not find anymore to vote on. I was either the Author or had already voted Certify. Someone else have to give the second vote.  Sad
RE: Suggestion for showing process within the PT - Chris Dee - 2018-11-29
(2018-11-28, 19:29)Gerald Lasser Wrote: That brings up also one more question: What are the 'hidden' commands the PT can do?
e.g. it can display more rows
http://www.ldraw.org/cgi-bin/tracker/activity.cgi?n=0,200
what other gems are there? Smile
The activity reporter (activity.cgi) has the following parameters:
- n=[start offset from top of list],[number or entries to show]
- t=[event-type] (as shown in Action column, e.g. submit, review, delete, etc)
- f =[file-path] (as used from the event link on the detail page)
The parts lister (ptlist.cgi) has the following parameters:
- subset=[filter] (one of certified, adminreview, memberreview, needsubfile, held)
- sort=[display sequence] (one of cert, file, type, title)
RE: Suggestion for showing process within the PT - Max Martin Richter - 2018-11-29
If could read Date and Time as well, it should be easy to create the infos for such an info page. :-)
RE: Suggestion for showing process within the PT - Gerald Lasser - 2018-12-01
(2018-11-29, 6:55)Chris Dee Wrote: The activity reporter (activity.cgi) has the following parameters:
Would some of those apply also to the mysubmits.cgi?
e..g if I want to see only my held files? I tried the above but it did not work
RE: Suggestion for showing process within the PT - Chris Dee - 2018-12-02
No, sorry, there is currently no subsetting support in mysubmits.cgi (or myreviews.cgi).
RE: Suggestion for showing process within the PT - Orion Pobursky - 2018-12-02
(2018-11-28, 15:38)Willy Tschager Wrote:
(2018-11-26, 17:03)Max Martin Richter Wrote: I think, this would increase the user experience, if it would be a subpage with a link from the front page. Actually I feel, that a normal user is not very satisfied, that the main page doesn't change the content that often and most of the AFOLS I know, don't even know about the PartsTracker and it's function and some of them had already asked me in the part, if LDraw is dead or not. With this future they could see, that something is going on and that several parts are updated or whatever.
Well, mirroring the Parts Tracker Activity Log to the home along with a thumbnail of the parts would help.
I might be able to bash something together. It would help if PTActivity had an RSS feed or JSON API but I think I can go without.
(2018-11-26, 17:03)Max Martin Richter Wrote: Dear all,
I got the request in the LAN forum, if it would be possible to bring an update with handled parts in a scheduled base - like every 2 weeks or every month.
The more I think of this idea, the more I like it. I think a list with new uploaded parts, parts with at least 2 cert votes, parts with Admin cert and parts that are released in an update could handle all these things.
Best regards
Max
Just realised why I have found this entire thread confusing. Did you mean process (a series of actions or steps taken in order to achieve a particular end) or progress (development towards an improved or more advanced condition)?
RE: Suggestion for showing process within the PT - Max Martin Richter - 2018-12-02
Best regards
Max
I'll write you an email for clarification this evening. ;-)
RE: Suggestion for showing process within the PT - Gerald Lasser - 2018-12-02
(2018-12-02, 11:40)Chris Dee Wrote:
(2018-12-01, 23:45)Gerald Lasser Wrote: Would some of those apply also to the mysubmits.cgi?
Thanks!
RE: Suggestion for showing process within the PT - Orion Pobursky - 2018-12-14
(2018-12-02, 16:19)Orion Pobursky Wrote:
(2018-11-28, 15:38)Willy Tschager Wrote: Well, mirroring the Parts Tracker Activity Log to the home along with a thumbnail of the parts would help.
I have implemented a feed of the most recent PT submit actions on the front page.
