[LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Printable Version
+--- Thread: [LDPartEditor] 0.8.44b Beta Released (Bug-Fix) (/thread-22861.html)
[LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Nils Schmidt - 2018-07-04
sorry, the last release had a bug. It's fixed now.
[Image: imgDuke2.png]
Changelog:
(0 new features and 1 bug fixes)
With this release the following critical issue is fixed:
  1. Clicking on the tabs no longer changed the 3D view. / Scrolling in the text editor didn't refresh line numbers.
What will the next release 0.8.45 deliver? Usability improvements, more toolbars and shortkeys.
  1. Download the zip-Archive
  3. On windows, double-click "LDPartEditor.exe" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Alternatively, you can download a setup file to install LDPE on Windows.
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
java -d64 version
RE: [LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Philippe Hurbain - 2018-07-04
Thanks, Nils!
RE: [LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Magnus Forsberg - 2018-07-05
That tiny vertex editor window is hugging my screen. It stays on top of all my open programs, if a vertex is selected.
RE: [LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Philippe Hurbain - 2018-07-06
Yes, already reported. If you want to switch to another program you have to iconize ldpe.
RE: [LDPartEditor] 0.8.44b Beta Released (Bug-Fix) - Willy Tschager - 2018-07-06
PathTruder is giving me a hard time. It seams broken in 43 and also 44. These files:
.dat   PathTruder.dat (Size: 309 bytes / Downloads: 5)
.dat   path1.dat (Size: 670 bytes / Downloads: 5)
.dat   path2.dat (Size: 742 bytes / Downloads: 4)
.dat   shape1.dat (Size: 285 bytes / Downloads: 4)
Work fine in LETGui but produce nothing in LDPE. What I'm doing wrong?
So far I never tested Pathtruder in LDPE, seemed (even) more complex to use than command line/letgui...
Vertex window stays on top of all open programs. - Nils Schmidt - 2018-07-06
(2018-07-05, 19:47)Magnus Forsberg Wrote: That tiny vertex editor window is hugging my screen. It stays on top of all my open programs, if a vertex is selected.
I created an issue (#700) and hope to fix that with a next release.
Help for PathTruder - Nils Schmidt - 2018-07-06
(2018-07-06, 9:26)Willy Tschager Wrote: PathTruder is giving me a hard time. It seams broken in 43 and also 44. These files:
Subfile references are currently not supported by LDPE's PathTruder.
Let me help you:
  1. Inline all references in the PathTruder.dat file until its full of coloured lines
  2. Select everything inside the PathTruder.dat file
  3. Open the PathTruder tool and click ok
RE: Help for PathTruder - Willy Tschager - 2018-07-07
Let me help you:
Works like a champ. Thx for the tip.
Milestone 0.8.45 is almost complete - Nils Schmidt - 2018-08-06
just wanted to say that I only need to finish one issue (#255) until milestone 0.8.45 is ready for release.
There will be a new release in August this year Smile
Cheers,
Nils
Milestone 0.8.45 is reached and will be deployed in the next 4-5 hours - Nils Schmidt - 2018-08-09
Hello,
milestone 0.8.45 is complete.
I will upload the new version in the next few hours (max. 4 or 5).
Cheers,
Nils
RE: Milestone 0.8.45 is reached and will be deployed in the next 4-5 hours - Johann Eisner - 2018-08-09
(2018-08-09, 17:40)Nils Schmidt Wrote: Hello,
Cheers,
Nils
