Which shortcuts should be in our library and which not? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Parts Tracker Discussion (https://forums.ldraw.org/forum-36.html) +--- Thread: Which shortcuts should be in our library and which not? (/thread-22798.html) |
Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 at the review of 15396c02.dat http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/15396c02.dat a discussion started about which shortcuts should be in our library and which not. let's continue the discussion here ![]() I copied the comments from that part's review to here, see below: RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 Chris Wrote:This shortcut is useful as a template or helper, but is not something that is delivered as an assembly by LEGO. Maybe we need a qualifier on the LDRAW_ORG line: RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 Steffen Wrote:I think everybody easily can see that. RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 Philo Wrote:I agree with Steffen, probably overkill to make this distinction. RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 arezey Wrote:I don't really like "Helper" because it seems to me as word cruft. It's like "thing" and "gizmo" and we don't use those either. I think we're currently using "Shortcut" for things that aren't really shortcuts. I'd rather see assemblies given their own proper part type instead of changing these which IMO are real shortcuts here. RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 MagFors Wrote:I agree with Chris and Santeri. RE: Which shortcuts should be in our library and which not? - Steffen - 2018-04-14 Steffen Wrote:I again disagree. My thoughts: Door + Frame Assemblies - Steffen - 2018-04-18 I wonder if we should have these Door + Frame assemblies http://www.ldraw.org/cgi-bin/ptpatterns.cgi?c=u9370 in our library. This would be the first Door + Frame assemblies when I see correctly. Up to now, we are only delivering the doors + frames separately. This is a similar question to the Wheels + Tyre assemblies question. But it is also a little different: finding the proper tyre for a wheel is more tedious than finding the proper door for a frame. My personal opinion currently is: - I would like to see the wheel+tyre assemblies official - I also like the door+frame assemblies, but I understand if people don't want them RE: Door + Frame Assemblies - Philippe Hurbain - 2018-04-18 I kind of think that door+frame assemblies would be significantly more useful than tire+ wheel ones: tire generally share the same origin as the rim so they are extremely simple to assemble. Proper assemblies of door+frame is often much more tricky. Actually I'd like to see shortcuts (in both cases) only if assembly is not obvious. RE: Door + Frame Assemblies - Roland Melkert - 2018-05-23 (2018-04-18, 6:48)Philippe Hurbain Wrote: I kind of think that door+frame assemblies would be significantly more useful than tire+ wheel ones: tire generally share the same origin as the rim so they are extremely simple to assemble. Proper assemblies of door+frame is often much more tricky. Placing them isn't that hard indeed, but finding the matching pair is imho. Although some kind of formatted keyword could solve that problem. RE: Door + Frame Assemblies - Steffen - 2018-05-24 (2018-05-23, 18:36)Roland Melkert Wrote: Although some kind of formatted keyword could solve that problem. I would find the presence of the simple wheel+tyre assemblies more helpful. Doing that avoids all the hassle of - having to define a new syntax - adjust all the parsers - make people understand how that is intended to work Instead, just offering the simple wheel+tyre assmblies shows the possible combinations. They really do not hurt. The amount of possible combinations still is small compared to the overall amount of files. For example, each time we do a renumbering with a MOVED-TO, we are creating small files. From my perspective, still releasing the wheel+tyre assemblies officially is the way to go. RE: Door + Frame Assemblies - Roland Melkert - 2018-05-24 (2018-05-24, 0:06)Steffen Wrote:(2018-05-23, 18:36)Roland Melkert Wrote: Although some kind of formatted keyword could solve that problem. It wouldn't need a new meta/syntax just a keyword which is present in both a tyre and any of its matching wheels. RE: Door + Frame Assemblies - Magnus Forsberg - 2018-05-24 (2018-05-24, 16:56)Roland Melkert Wrote:(2018-05-24, 0:06)Steffen Wrote: I would find the presence of the simple wheel+tyre assemblies more helpful. That is already present in all of the tyres and rims following the naming nomenclature. The rim diameter is a common denominator. |
