How do you convert a .STEP file to use with LDraw? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Off Topic (https://forums.ldraw.org/forum-28.html) +--- Forum: Off-Topic (https://forums.ldraw.org/forum-27.html) +--- Thread: How do you convert a .STEP file to use with LDraw? (/thread-22787.html) |
How do you convert a .STEP file to use with LDraw? - ArloB - 2018-04-03 My question might be totally "n00b" but I have a .STEP file that I found and need to use it with LDraw software or with the Bricklink Stud.io in a 3D model that I built for my students. How do you convert the .STEP file to another format that I could import? Or is there a series of steps to get to this process? I would really appreciate your help. Thank you. RE: How do you convert a .STEP file to use with LDraw? - Steffen - 2018-04-03 what is a .step file? can you point us to the application that produced it? or what file format it contains? when googling, I found various results, so I'm unclear about what application has produced your file. RE: How do you convert a .STEP file to use with LDraw? - ArloB - 2018-04-03 (2018-04-03, 18:05)Steffen Wrote: what is a .step file? Hi, Steffen. Thanks for replying. A step file is made in some type of CAD software to create a 3D model to use in a 3D printer for instance. Here is an example of what I am referring to: https://grabcad.com/library/rotacaster-48mm-double-35a-lego-hub-1 RE: How do you convert a .STEP file to use with LDraw? - Philippe Hurbain - 2018-04-03 (2018-04-03, 17:42)ArloB Wrote: My question might be totally "n00b" but I have a .STEP file that I found and need to use it with LDraw software or with the Bricklink Stud.io in a 3D model that I built for my students. I stumbled on this problem some time ago, and had a hard time finding a converter not costing an arm... Here is the process I use: - Download and install FreeCAD https://www.freecadweb.org/ - Open your STEP file in FreeCAD - Switch FreeCAD to mesh design mode - Meshes -> Create mesh from shape (option: standard meshing) - Select the meshed result, then meshes -> export mesh -> ASCII STL (*.stl) - Convert the resulting stl to LDraw file using stl2dat (https://sourceforge.net/projects/stl2dat/) stl2dat is also included in LETGUI distribution that has the benefit of providing a GUI around command line tools (http://ldraw.heidemann.org/index.php?page=letgui) Feel free to ask if you need more details! RE: How do you convert a .STEP file to use with LDraw? - ArloB - 2018-04-03 (2018-04-03, 18:24)Philippe Hurbain Wrote:(2018-04-03, 17:42)ArloB Wrote: My question might be totally "n00b" but I have a .STEP file that I found and need to use it with LDraw software or with the Bricklink Stud.io in a 3D model that I built for my students. Hi, Philippe. I am trying this right now and downloaded everything. Thank you so much!! RE: How do you convert a .STEP file to use with LDraw? - Aidan Blake - 2019-10-13 (2018-04-03, 18:24)Philippe Hurbain Wrote: I stumbled on this problem some time ago, and had a hard time finding a converter not costing an arm... Here is the process I use: RE: How do you convert a .STEP file to use with LDraw? - Philippe Hurbain - 2019-10-13 Quote:Thanks a lot! Your method works for me too because I use Artec Studio and it supports .stl file format. But what if I have .obj files also? Any tips you might have to give?Convert first the .obj to .stl, then use stl2dat. This should be easy since both stl and obj file format are extremely common and available for most tools. |
