Issue with AIOI 2018-01 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: All Other Programs. (https://forums.ldraw.org/forum-26.html) +--- Thread: Issue with AIOI 2018-01 (/thread-22769.html) |
Issue with AIOI 2018-01 - Simon Denscombe - 2018-03-20 I downloaded the AIOI 2018-01 and installed by accepting all the defaults. LDView opens and renders Cafe Corner correctly. However when I open LDCAD I get the following: LDCAD 1.6a Error can't open file 'C:\Users\Public\Documents\LDraw\complete.zip' (error 2:the system cannot find the file specified.) [OK] I have checked that file path and the file does not exist. Any ideas? This is on a fresh PC that hasn't had any LDraw applications installed on it before. Operating System is Windows 10 1703 64-Bit. RE: Issue with AIOI 2018-01 - Willy Tschager - 2018-03-20 (2018-03-20, 17:46)Simon Denscombe Wrote: I downloaded the AIOI 2018-01 and installed by accepting all the defaults. I'll investigate. Please upload your log file under c:\Windows\LDraw RE: Issue with AIOI 2018-01 - Roland Melkert - 2018-03-20 (2018-03-20, 20:04)Willy Tschager Wrote:(2018-03-20, 17:46)Simon Denscombe Wrote: LDCAD 1.6a Error If complete.zip was at that location at one point (temporary?) and ldcad is using "C:\Users\Public\Documents\LDraw\" as the default library location given in LDCad.cfg. It could result in this message when complete zip is removed later. As complete.zip has priority over loose files when first checking for a library in the given folder. RE: Issue with AIOI 2018-01 - Simon Denscombe - 2018-03-21 (2018-03-20, 20:04)Willy Tschager Wrote:(2018-03-20, 17:46)Simon Denscombe Wrote: I downloaded the AIOI 2018-01 and installed by accepting all the defaults. Setup Log.txt attached. RE: Issue with AIOI 2018-01 - Willy Tschager - 2018-03-21 (2018-03-21, 9:28)Simon Denscombe Wrote:(2018-03-20, 20:04)Willy Tschager Wrote: I'll investigate. Please upload your log file under c:\Windows\LDraw Thanks for the file. I was able to track the bug and it should work now. I'll upload version2 which also comes with LeoCAD 18-02 and LDCad 1.6b in the coming days. w. RE: Issue with AIOI 2018-01 - End Unsure - 2018-04-23 (2018-03-21, 11:20)Willy Tschager Wrote:(2018-03-21, 9:28)Simon Denscombe Wrote: Setup Log.txt attached. I've got the same issue, I was wondering if the updated AiOI was available some where yet? RE: Issue with AIOI 2018-01 - Willy Tschager - 2018-04-24 (2018-04-23, 22:17)End Unsure Wrote:(2018-03-21, 11:20)Willy Tschager Wrote: Thanks for the file. I was able to track the bug and it should work now. I'll upload version2 which also comes with LeoCAD 18-02 and LDCad 1.6b in the coming days. The release candidate for version 2 can be found here: http://www.holly-wood.it/tmp/LDraw_AIOI_2018-01_setup_32bit_v2.exe w. RE: Issue with AIOI 2018-01 - Simon Denscombe - 2018-04-24 (2018-04-24, 8:05)Willy Tschager Wrote:(2018-04-23, 22:17)End Unsure Wrote: I've got the same issue, I was wondering if the updated AiOI was available some where yet? Seems to work for me now. Thanks. RE: Issue with AIOI 2018-01 - End Unsure - 2018-04-24 (2018-04-24, 8:05)Willy Tschager Wrote:(2018-04-23, 22:17)End Unsure Wrote: I've got the same issue, I was wondering if the updated AiOI was available some where yet? Thank you very much sir, I knew it must be done but I wasn't able to find it. |
