Creator Expert - Printable Version
+--- Thread: Creator Expert (/thread-22701.html)
Pages: 1 2 3 4 5 6 7
RE: [Placeholder] 10294-1 Titanic - Natalie Schauw - 2021-11-15
(2021-11-09, 7:51)Max Martin Richter Wrote: This is a placeholder for the Titanic.
I'll start to build this weekend. If anybody owns the set I would like to create the patterns and flags as well.
I'm also trying to build the Titanic, but as you probably have noticed, there are a lot of pieces missing. Do you know how to make these missing pieces?
RE: [Placeholder] 10294-1 Titanic - Max Martin Richter - 2021-11-19
(2021-11-15, 21:01)Natalie Schauw Wrote: I'm also trying to build the Titanic, but as you probably have noticed, there are a lot of pieces missing. Do you know how to make these missing pieces?
Except of the patterned parts and flags I noticed, that several click hinges ares missing. Actually I substitute them with available ones. Some of them are easy to create, some not. I'm going to create some of them parallel while modelling and some when the model is finished.
Do you own the set physically? If yes, you could provide some pictures or scans of the patterns and the flags. ;-)
RE: [Placeholder] 10294-1 Titanic - Natalie Schauw - 2021-11-20
(2021-11-19, 21:34)Max Martin Richter Wrote: Except of the patterned parts and flags I noticed, that several click hinges ares missing. Actually I substitute them with available ones. Some of them are easy to create, some not. I'm going to create some of them parallel while modelling and some when the model is finished.
Unfortunately I do not own the set physically :-(
