Thumbnails by LDView - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: Thumbnails by LDView (/thread-22688.html) |
Thumbnails by LDView - Jaco van der Molen - 2018-02-02 Hi all, When I installed LDView I configured it to generate the thumbnails in Windows Explorer. Lately when opening folders with LDraw files Explorer crashes almost every time. How do I stop LDView from generating thumbnails? This is getting very annoying (sorry about that Travis ;-) Jaco RE: Thumbnails by LDView - Magnus Forsberg - 2018-02-02 (2018-02-02, 12:48)Jaco van der Molen Wrote: Hi all, I think it has something to do with the updates of Win10. I'm experiencing something similar. Explorer doesn't crash, but it seems to not remember having created thumbnails. Everytime I restart my pc from Hibernate-mode and open a folder, all the thumbs are gone and LDView have to regenerate them. Annoying, indeed... RE: Thumbnails by LDView - Willy Tschager - 2018-02-02 You have to unregister the LDViewThumbs.dll (based on the 32 or 64) using C:\Windows\System32\regsvr32.exe. The easy way would be uninstalling the AIOI which unregisters at shutdown. w. RE: Thumbnails by LDView - Travis Cobbs - 2018-02-03 (2018-02-02, 12:48)Jaco van der Molen Wrote: Hi all, First of all, I cannot reproduce this problem in my fully updated 64-bit Windows 10. So, unfortunately, I'm not likely going to be able to track down and fix whatever is causing it. The thumbnail generator is actually quite simple, since it spawns an external instance of LDView.exe (or LDView64.exe) to do the actual work. But figuring out why it is crashing Explorer is well-nigh impossible without me being able to reproduce the crash. Willy's instructions will uninstall, and regsvr32 can be used to turn off thumbnail generation manually without uninstalling. If you want to manually unregister (using regsvr32), you would do the following:
I would appreciate it if you used the AIOI if you would uninstall the whole AIOI and then install LDView standalone with Explorer thumbnails enabled. If they then work, then that probably indicates a problem in the AIOI (which doesn't use LDView's standalone installer). If it still crashes Explorer, then at least we know that the AIOI isn't the source of the problem. Note that I'm not expecting the AIOI to be the source of the problem; it's just one variable that is (relatively) easy to check. RE: Thumbnails by LDView - Travis Cobbs - 2018-02-03 (2018-02-03, 5:24)Travis Cobbs Wrote: I would appreciate it if you used the AIOI if you would uninstall the whole AIOI and then install LDView standalone with Explorer thumbnails enabled. If they then work, then that probably indicates a problem in the AIOI (which doesn't use LDView's standalone installer). If it still crashes Explorer, then at least we know that the AIOI isn't the source of the problem. Note that I'm not expecting the AIOI to be the source of the problem; it's just one variable that is (relatively) easy to check. I installed the AIOI (which I see appears to be 32-bit-only), but I still couldn't reproduce the Explorer crash. RE: Thumbnails by LDView - Steffen - 2018-02-03 could you post the contents of your registry tree below Code: HKEY_CURRENT_USER\Software\Travis Cobbs\LDViewhere? maybe that could help for analysis. You can save that registry subtree by using regedit.exe RE: Thumbnails by LDView - Jaco van der Molen - 2018-02-03 (2018-02-03, 5:24)Travis Cobbs Wrote:(2018-02-02, 12:48)Jaco van der Molen Wrote: Hi all, Ok I’ll look in to it Monday since it is my computer at work that has the problem. RE: Thumbnails by LDView - Travis Cobbs - 2018-02-04 (2018-02-03, 10:25)Steffen Wrote: could you post the contents of your registry tree below The thing is, the LDView Thumbnail DLLs don't generate the thumbnails. All they do is construct a command line which they use to launch LDView, which generates the thumbnails. So, if LDView crashes during the process, the thumbnail generation will fail, but it shouldn't crash Windows Explorer. RE: Thumbnails by LDView - Johann Eisner - 2018-02-04 (2018-02-04, 3:01)Travis Cobbs Wrote:I think the same.(2018-02-03, 10:25)Steffen Wrote: could you post the contents of your registry tree below Had the same problem on a Win7 system, but only generating thumbnails from big models. When i generate a instruction from this models with LPub, LDView crash also, because my system RAM was to small. Solved this problem by changing the memory usage in LDView. LDView is slower, but it helps. RE: Thumbnails by LDView - Jaco van der Molen - 2018-02-05 OK, I just removed everything from the registry that had LDViewThumbs.dll in it. I dit not installed LDraw with the AIOI. RE: Thumbnails by LDView - Jaco van der Molen - 2018-02-08 (2018-02-05, 8:52)Jaco van der Molen Wrote: OK, I just removed everything from the registry that had LDViewThumbs.dll in it. Just to inform you all: once I removed the registry entry for LDViewThumbs no crashes for the file explorer have occurred on my Windows 7 pro PC. |
