1970's - LEGOland and hobby sets - Printable Version
+--- Thread: 1970's - LEGOland and hobby sets (/thread-22660.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
RE: 674-1 - Forklift and Truck - Magnus Forsberg - 2021-03-28
(2021-03-28, 14:31)Philippe Hurbain Wrote: Making a spring is not a very big issue (could probably be derived from https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/70181c01.dat), but where is it supposed to attach to the forklift parts???
Do you know the correct number of that spring? Could it be the same?
RE: 674-1 - Forklift and Truck - Philippe Hurbain - 2021-03-28
(2021-03-28, 15:25)Magnus Forsberg Wrote: Do you know the correct number of that spring? Could it be the same?
The true question is - is there a spring??? Mechanism could simply rely on friction between 3430 and 3431... I see none on all photos I checked!
Yes, it has.
I remember having one as a kid and it was a lot of fun shooting stuff in the air with the fork. Smile
And the parts have hooks for a spring.
(2021-03-28, 17:11)Magnus Forsberg Wrote: Yes, it has.
Yes... https://www.bricklink.com/v2/catalog/catalogitem.page?P=bb0217&idColor=22#T=C&C=22
And advice in 3430 and so called "3429": 0 // Needs work: Spring attachment
I said so called because imho it's actually 3431!
RE: 674-1 - Forklift and Truck - Joshua Delahunty - 2021-03-28
It's definitely not the same spring.
70181 is from 1983 (for the newer, larger 73367 FORK-LIFT TRUCK), while 74603 FORK-LIFT TRUCK (the one being shown here) dates as far back as 1972.
Plus, I did some measurements for Philo at his request. Smile
The older spring is actually of a larger diameter, and is shorter.
In addition to the spring, there are connection points missing from the platform and the standard for the spring to attach to.  I gave Philo some reference photos and suggestions (one could "cheat" and just use a cylinder at the top, even though the shape is more like a box with the top two edges rounded off. The peg on the platform is a lot more involved, if one wants to sweat the details.)
(2021-03-28, 17:44)Philippe Hurbain Wrote: Yes... https://www.bricklink.com/v2/catalog/catalogitem.page?P=bb0217&idColor=22#T=C&C=22
Philo is right, this is one of the oldest misnumberings in LDRAW.
3429 is unknown, but definitely not the FORK-LIFT PLATFORM, it should be 3431. (3430 is correct as the FORK-LIFT STANDARD)
Note: 3429 is also definitely not the spring; which would have a 6xxx or 7xxxx numbering, owing to the fact that it is metal.
RE: 1970's - LEGOland and hobby sets - Takeshi Takahashi - 2021-04-04
Finally completed this set!!
Set: 374-1 Fire Station
OMR Compliant: Currently no (Unofficial stickers not inlined)
Known errors: none
Done with: MLCad 3.51
.mpd   374-1 - Fire Station.mpd (Size: 20.36 KB / Downloads: 4)
RE: 1970's - LEGOland and hobby sets - Willy Tschager - 2021-04-14
.mpd   373 - Offshore Rig with Fuel Tanker.mpd (Size: 323.19 KB / Downloads: 3)
Known errors: None
Done with: LDCad 1.6d
Note: A set I wanted badly as a kid but newer got - now I have and in perfect shape. Love being an AFoL.
Hint: Stickers are at the PT ready to be reviewed
RE: 1970's - LEGOland and hobby sets - Jeremie Guillaume - 2021-05-07
Hello Takeshi,
Here is the string I made for this nice 670 set. I think it's not too bad... Hope you'll like it Smile
.mpd   670-1 - Mobile Crane.mpd (Size: 68.74 KB / Downloads: 6)
Made with LDCad the instructions found on JC Tchang's site about how to make a string with the LS60 LSynth part (inlined in the mpd). And quite some time playing with Bezier curves while taking a real-world knot as a reference...
You'll see I fixed three minor glitches, too:
- two 3020's were inverted among building steps
- the crane was vertically overlapping the truck by 8 LDUs
- the red block was lower than (invisible) ground
Finally I couldn't resist but put the stickers... but of course, thanks must go to yourself for having created two of those (BTW I'm impressed by the large numbers of stickers you submitted recently on the PT, great work !)
RE: 1970's - LEGOland and hobby sets - Philippe Hurbain - 2021-05-08
Great collaborative work on this one Wink
I'm especially fond of rope knot!
