Using LDCad - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: Using LDCad (/thread-22631.html) Pages:
1
2
RE: Using LDCad - Mindaugas - 2018-04-21 (2018-04-21, 16:45)Roland Melkert Wrote:Thanks(2018-04-21, 12:13)Mindaugas Wrote: I 'd like to know, is it possible to merge all submodels into one main model without loosing steps?Yes: Maybe there is a LDCad tutorial or anything else where I could learn, how to use buffer exchange? I even cant find it.. to low IQ I found MLCad tutorial, and it looks like not what I'm looking for. It effect only the view? I need to move the pin on further(later) step, not on the current RE: Using LDCad - Roland Melkert - 2018-04-22 (2018-04-21, 18:58)Mindaugas Wrote: Maybe there is a LDCad tutorial or anything else where I could learn, how to use buffer exchange? I even cant find it.. to low IQ Buffer exchange it not a LDCad specific feature, it is a collection of special LDraw meta lines. Which basically let you take a 'picture' of the current model which can then be used to restore that situation some time later (removing anything added since the picture was taken). This can be used to place a pin at two different locations in between steps. Downside is you have to re-add all other parts of that step too. It is discussed in some more detail here: https://www.eurobricks.com/forum/index.php?/forums/topic/159626-lpub3d-ldcad-asking-for-help/ RE: Using LDCad - Jaco van der Molen - 2018-05-29 (2018-04-22, 19:52)Roland Melkert Wrote:(2018-04-21, 18:58)Mindaugas Wrote: Maybe there is a LDCad tutorial or anything else where I could learn, how to use buffer exchange? I even cant find it.. to low IQ Perhaps my tutorial on Buffer exchange can enlighten it too? Found here: https://sites.google.com/site/binarybricks/mlcad/lessen/buffer-uitwisselen In Dutch, but you can translate by Google Translate. RE: Using LDCad - Mindaugas - 2018-05-29 (2018-05-29, 11:57)Jaco van der Molen Wrote: Perhaps my tutorial on Buffer exchange can enlighten it too? thanks a lot |
