[LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: Parts Author Tools (https://forums.ldraw.org/forum-24.html) +--- Thread: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) (/thread-22288.html) |
[LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Nils Schmidt - 2017-08-30 Hi, here is a release which wipes out some critical bugs. As always, you can download LDPE from this page: http://nilsschmidt1337.github.io/ldparteditor/ Changelog: (7 bug fixes) The following critical issues were fixed:
What will the next release 0.8.38 deliver? A new CSG engine with great triangulation features... The program was tested intensively with "real world" files. However, it is still a beta version and something can go wrong in about 100.000 lines of code. Make sure that you choose the right architecture for your OS and Java Virtual Machine (JVM) (64bit or 32bit). A short guide how to check if a 64bit JVM is installed on your system is located at the bottom of this message.
LDPE is a 3D CAD application: The overall system requirements are higher. While I recommend to use a powerful 64-bit multicore system, it could be possible, to run LDPE on older machines as well. System Requirements: Minimum System Requirements:
How to check your JVM version (32- or 64-bit): -------------------------------------------------------------------------------- You can try on the command line: Code: java -d64 version If it's not a 64-bit version, you'll get a message that looks like: This Java instance does not support a 64-bit JVM. Please install the desired version. New CSG Engine - Nils Schmidt - 2017-09-18 I am working on a new CSG engine which will generate less triangles and a better overall triangulation. There are already some promising results, but I need to define more testcases to deliver a rock-solid implementation in the end. RE: New CSG Engine - Philippe Hurbain - 2017-09-19 (2017-09-18, 18:44)Nils Schmidt Wrote: I am working on a new CSG engine which will generate less triangles and a better overall triangulation.An incentive to finally learn CSG in LDPE ...and thanks for the headup, I somehow missed that release announcement (and did sometimes noticed a slowdown - nice to know it's fixed now!) RE: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Willy Tschager - 2017-09-20 Bug of the day: * No notification pop-up when update is completed * Prog does not store my full screen window status but reopens the window a bit smaller * Prog does not store the status of the "Move adjacent data" button. Launches always with unpressed status * Adding a blank while in "Triple manipulation" in the text editor causes havoc. I would expect that the rectangle around the triples are a safe harbour as long as I don't select something else independently what I'm inserting. w. RE: New CSG Engine - Gerald Lasser - 2017-09-20 (2017-09-18, 18:44)Nils Schmidt Wrote: I am working on a new CSG engine which will generate less triangles and a better overall triangulation. You could use the code for the Jurassic World Sphere to test: https://forums.ldraw.org/thread-16357.html?highlight=CSG I managed to do it with different steps and with Intersector to reduce the number of triangles. I promis I finish the part soon, right now comparing it to the LDD version RE: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Magnus Forsberg - 2017-09-26 Bug report
edges.png (Size: 10.99 KB / Downloads: 202) This picture show an example of two selectable edges, included in prims, but the edge at the red arrow is not selectable. RE: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Philippe Hurbain - 2017-10-31 Probably the thing I miss the most in LDPE (already asked for that ): a slanting tool... RE: New CSG Engine - Nils Schmidt - 2017-11-04 (2017-09-20, 22:31)Gerald Lasser Wrote:(2017-09-18, 18:44)Nils Schmidt Wrote: I am working on a new CSG engine which will generate less triangles and a better overall triangulation. Thanks Gerald! I will use the sphere to test it. I already knew something about your work (J.C. Tchang mentioned it in his LDPE manual). My plan is to release the new CSG engine in December. I started to optimise the CSG triangulation in September, but then I had improve the overall stability of the algorithm and discard the triangulation optimisations. Now, I am working on triangle optimisations again. Bug report: MeshReducer does a wrong check for common vertices - Nils Schmidt - 2017-11-12 Today, I fixed an issue (#608) which is related to the MeshReducer tool. At the moment there is a chance that MeshReducer could generate holes (There was a wrong check for common adjacent vertices). The bugfix will be included in the next 0.8.38 release. Bug report: TJunctionFinder does not fix t-junctions anymore. - Nils Schmidt - 2017-11-12 Today, I fixed another issue (#608) which is related to the TJunctionFinder tool. At the moment the tool will not fix t-junctions anymore ("Find Only" still works). The bugfix will be included in the next 0.8.38 release. Edge selection bugs - Nils Schmidt - 2017-11-12 I created issues for this problem (#610, #611). A temporary workaround might be to enable View Actions -> HiddenVertices (context menu from the 3D view) this will allow you to select all lines. The drawback is that it also selects hidden lines. Slanting tool? - Nils Schmidt - 2017-11-12 (2017-10-31, 17:45)Philippe Hurbain Wrote: Probably the thing I miss the most in LDPE (already asked for that ): a slanting tool... What is a slanting tool? RE: Slanting tool? - Philippe Hurbain - 2017-11-12 (2017-11-12, 13:25)Nils Schmidt Wrote:A way to deform primitives (slant them). There is an exhaustive tutorial here http://jc-tchang.philohome.com/manuel/prim_def.htm - unfortunately in French, but I guess that Google translate will be good enough!(2017-10-31, 17:45)Philippe Hurbain Wrote: Probably the thing I miss the most in LDPE (already asked for that ): a slanting tool... Another example (from https://forums.ldraw.org/thread-12247.html): - We need to project again the surface. We do that with a slant transformation. In the initial file, we see that for a 144 ldu height we need to tilt in y direction by 40 ldu. This gives the slant ratio: 40/144=0.2777778. The transformation matrix is thus: Code: Code: 1 0.2777778 0 0 1 0 0 0 1 RE: Slanting tool? - Gerald Lasser - 2017-11-12 (2017-11-12, 13:25)Nils Schmidt Wrote:(2017-10-31, 17:45)Philippe Hurbain Wrote: Probably the thing I miss the most in LDPE (already asked for that ): a slanting tool... I called it skewing in this thread https://forums.ldraw.org/thread-18771-post-18771.html?highlight=rectangle#pid18771 Store the status of "Move Adjacent Data" in the user settings. - Nils Schmidt - 2017-11-12 (2017-09-20, 7:25)Willy Tschager Wrote: * Prog does not store the status of the "Move adjacent data" button. Launches always with unpressed status I implemented this feature today (#613). RE: Slanting tool? - Magnus Forsberg - 2017-11-12 Here is another example/question: How do I rotate an edge around an sloping cylinder ? New CSG Engine is done / Christmas will be a little bit earlier ;) - Nils Schmidt - 2017-11-16 (2017-09-20, 22:31)Gerald Lasser Wrote:(2017-09-18, 18:44)Nils Schmidt Wrote: I am working on a new CSG engine which will generate less triangles and a better overall triangulation. Gerald, I finished the new engine today and I got tears in my eyes. The result is outstanding. Nearly super-human! I attached the raw CSG result to this post (rectifier was only used to save some space). With this new engine, all I have to do is: 1. (optional) wait until the CSG shape is fully optimised -> there is no popup dialog. The iterative optimization is runs on a background task. You can even modify other files with LDPE during the CSG optimization. 2. Inline the CSG_COMPILE meta command. 3. (optional) round / use Rectifier / minor cleanup etc. There will be an option to turn this optimisation on/off (its on by default) and to customise some thresholds! There is a collinearity threshold for the edge collapsing process and a minimum point-to-line distance for t-junction vertices. I will release LDPE 0.8.38 in December. Have to finish the backlog first and do some more testing. RE: [LDPartEditor] Last character of file not selected - Philippe Hurbain - 2017-11-17 A very minor one that bothers me from time to time... if I double click on the last element of last line of file (when there is no blank line below) then the last character is not selected. eg. if last line is 1 16 0 3 0 -10 0 0 0 11 0 0 0 -10 1-8edge.dat and it double click on 1-8edge.dat then only 1-8edge.da is selected. RE: Last character of file not selected - Nils Schmidt - 2017-11-17 (2017-11-17, 9:22)Philippe Hurbain Wrote: A very minor one that bothers me from time to time... if I double click on the last element of last line of file (when there is no blank line below) then the last character is not selected. eg. if last line is 1 16 0 3 0 -10 0 0 0 11 0 0 0 -10 1-8edge.dat and it double click on 1-8edge.dat then only 1-8edge.da is selected. I fixed this issue today (#618). It will be included in the 0.8.38 release. RE: New CSG Engine is done / Christmas will be a little bit earlier ;) - Gerald Lasser - 2017-11-18 (2017-11-16, 21:46)Nils Schmidt Wrote: Gerald, I finished the new engine today and I got tears in my eyes. The result is outstanding. Nearly super-human! Wow! This is a really great result. You did a really wonderful job! Looking forward to the release! RE: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Rudolph Bosman - 2017-11-19 Hi Nils, Is there by any chance a 32 bit version?? (i am still on old school Regards 32-bit release? - Nils Schmidt - 2017-11-20 (2017-11-19, 17:29)Rudolph Bosman Wrote: Hi Nils, Hi Rudolph, unfortunately, I am not able to provide support for 32-bit OS versions anymore. LDPartEditor depends on third party libraries which have already dropped support for 32-bit. Best, Nils RE: 32-bit release? - Philippe Hurbain - 2017-11-20 Maybe someone still has an ooooold 32bits version? RE: [LDPartEditor] Part type for new parts - Philippe Hurbain - 2017-11-21 Minor annoyance: when I create a new file, it receives a header that contains an invalid "0 !LDRAW_ORG" statement. Problems Hints section tells me that part type information is missing, then if I make a quick fix it adds a proper "0 !LDRAW_ORG Unofficial_Part" statement but doesn't remove the truncated "0 !LDRAW_ORG" one. RE: [LDPartEditor] Part type for new parts - Nils Schmidt - 2017-11-22 (2017-11-21, 9:21)Philippe Hurbain Wrote: Minor annoyance: when I create a new file, it receives a header that contains an invalid "0 !LDRAW_ORG" statement. Problems Hints section tells me that part type information is missing, then if I make a quick fix it adds a proper "0 !LDRAW_ORG Unofficial_Part" statement but doesn't remove the truncated "0 !LDRAW_ORG" one. I fixed this issue today (#628). It will be included in the 0.8.38 release (on ~1st December 2017). RE: 32-bit release? - Nils Schmidt - 2017-11-22 (2017-11-20, 19:18)Philippe Hurbain Wrote: Maybe someone still has an ooooold 32bits version? Version 0.8.24 has 32-bit support. This release is about a year old. You can download it here: https://github.com/nilsschmidt1337/ldparteditor/releases/tag/v0.8.24-beta RE: [LDPartEditor] Part type for new parts - Magnus Forsberg - 2017-11-22 (2017-11-22, 19:33)Nils Schmidt Wrote: I fixed this issue today (#628). Will the same fix also correctly change a file from "Part" to "Unofficial_Part"? I've been reworking a lot of parts lately and had to manually delete the old line, "0 !LDRAW_ORG Part" RE: 32-bit release? - Rudolph Bosman - 2017-11-23 (2017-11-20, 17:42)Nils Schmidt Wrote:(2017-11-19, 17:29)Rudolph Bosman Wrote: Hi Nils, Hi Nils, ok, fully understandable. it has beem anyway a long time i wanted to upgrade to 64 bit, so i am going to do it and get over and done with it. Thanks for motivating me to do it finally. (ps. i am very exited to upgrade) Best, Rudolph RE: [LDPartEditor] Part type for new parts - Philippe Hurbain - 2017-11-23 This wouldn't hurt indeed... Nonetheless, Datheader proposes to do that change automagically. RE: [LDPartEditor] 0.8.37 Beta Released (Critical Bug Fix) - Willy Tschager - 2017-11-23 Just to let you know that I have given up on my wish to see the Front, Left, Top, icons mirrored to the toolbar ;-) Thx, w. RE: [LDPartEditor] isecalc - Philippe Hurbain - 2017-11-23 Very, very minor improvement: Isecalc is almost never on whole file, and should default to act on current selection. RE: [LDPartEditor] isecalc - Gerald Lasser - 2017-11-23 (2017-11-23, 13:16)Philippe Hurbain Wrote: Very, very minor improvement: Isecalc is almost never on whole file, and should default to act on current selection.Adding to this, the same should apply for "add line intersection points" This works also only for the whole file and sometime generates a wild selection of vertices... RE: [LDPartEditor] isecalc - Philippe Hurbain - 2017-11-23 (2017-11-23, 15:48)Gerald Lasser Wrote: Adding to this, the same should apply for "add line intersection points" This works also only for the whole file and sometime generates a wild selection of vertices...Looks like I am not aware of this tool... Where do I find this? RE: Slanting tool? - Nils Schmidt - 2017-11-23 I created issue #614 for the slanting tool. Where is "add line intersection points"? - Nils Schmidt - 2017-11-23 (2017-11-23, 16:28)Philippe Hurbain Wrote:(2017-11-23, 15:48)Gerald Lasser Wrote: Adding to this, the same should apply for "add line intersection points" This works also only for the whole file and sometime generates a wild selection of vertices...Looks like I am not aware of this tool... Where do I find this? It's not a tool. It's a button next to the "C2L" button on the 3D editor toolbar. Scope of "add line intersection points" - Nils Schmidt - 2017-11-23 (2017-11-23, 15:48)Gerald Lasser Wrote: Adding to this, the same should apply for "add line intersection points" This works also only for the whole file and sometime generates a wild selection of vertices... If you do a selection, it works for the selection. Otherwise it would process the whole file. There might be some other disadvantages when the "no selection -> whole file" behaviour is disabled: - If you try to learn LDPE and you click on this button nothing will happen, because it requires a selection. - I could implement a popup dialog, which will ask if you really want to apply it to the whole file, but I have some UX concerns. What is your opinion? Scope of isecalc - Nils Schmidt - 2017-11-23 (2017-11-23, 13:16)Philippe Hurbain Wrote: Very, very minor improvement: Isecalc is almost never on whole file, and should default to act on current selection. I created an issue (#629). The feature will be included in the next release. 3D perspectives on toolbar - Nils Schmidt - 2017-11-23 (2017-11-23, 12:17)Willy Tschager Wrote: Just to let you know that I have given up on my wish to see the Front, Left, Top, icons mirrored to the toolbar ;-) Okay. RE: 32-bit release? - Nils Schmidt - 2017-11-23 (2017-11-23, 8:44)Rudolph Bosman Wrote:(2017-11-20, 17:42)Nils Schmidt Wrote: Hi Rudolph, off-topic: Good luck and enjoy your new PC build! :) There is a low chance that I will upgrade in the next year... I have no logic reason to do so... the CPU evolution is not so fast, compared to graphic cards and harddrives. 2018 will be the year of Ryzen 2, Threadripper 2, and Intel Ice Lake. I will probably buy new hardware in 2020. RE: Scope of "add line intersection points" - Gerald Lasser - 2017-11-23 (2017-11-23, 20:01)Nils Schmidt Wrote:(2017-11-23, 15:48)Gerald Lasser Wrote: Adding to this, the same should apply for "add line intersection points" This works also only for the whole file and sometime generates a wild selection of vertices... I observe that on larger files this may start a long(er) running job that makes you wonder what it is doing. I tried doing it with selecting only the lines I would like to intersect, but I got the impression that it did not always do what I wanted, however when applying it to the whole file it worked. It generates additional vertices that I don't find on any line. When I get it the next time, I will post it. The pop-up, if nothing is selected, would be an improvement in my opinion as you still have the chance to cancel the operation. Thansk RE: Scope of "add line intersection points" - Philippe Hurbain - 2017-11-24 Ah - yes of course I know this function (I asked for it!) but I never had the idea to use it without a selection. Popup seems the best solution ("a selection of edge lines is needed" + close button, or something like that). RE: Scope of "add line intersection points" - Nils Schmidt - 2017-11-25 (2017-11-24, 9:44)Philippe Hurbain Wrote: Ah - yes of course I know this function (I asked for it!) but I never had the idea to use it without a selection. Popup seems the best solution ("a selection of edge lines is needed" + close button, or something like that). I implemented a popup and a dialog with a progressbar and a cancel button yesterday (#630). Quick fix for missing "Unofficial_" prefix - Nils Schmidt - 2017-11-26 (2017-11-22, 22:03)Magnus Forsberg Wrote: Will the same fix also correctly change a file from "Part" to "Unofficial_Part"? I fixed this issue today (#631). Someday, I will implemented a feature which removes the UPDATE YYYY-MM suffix, too. RE: Quick fix for missing "Unofficial_" prefix - Magnus Forsberg - 2017-11-26 (2017-11-26, 20:50)Nils Schmidt Wrote: I fixed this issue today. Nice. RE: Scope of "add line intersection points" - Gerald Lasser - 2017-11-26 (2017-11-25, 13:52)Nils Schmidt Wrote: I implemented a popup and a dialog with a progressbar and a cancel button yesterday (#630). Great! Thank you! Quick fix for UPDATE date in the part type - Nils Schmidt - 2017-11-27 (2017-11-26, 20:50)Nils Schmidt Wrote: Someday, I will implement a feature which removes the UPDATE YYYY-MM suffix, too. Today, I implemented a quick fix to remove the UPDATE from the type (#633). |
