Texture mapping - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: Texture mapping (/thread-22213.html) |
RE: Texture mapping - Alexander Etges - 2019-03-12 Hello @All of you! as I am a huge fan of the Brickheadz, I'm always searching for a way to get the unique bricks for the SDCC exclusives and like Mr. Wissink said a while ago, I don't want to spend this huge amount of money to get them and so I found this nice Forum. If this still an active Thread I like to ask Mr. van der Molen if you're still designing the bricks!? I could provide some pictures of the unique bricks in hopes that you can design them... Keep up the great work and thx in advance! RE: Texture mapping - Jaco van der Molen - 2019-03-12 (2019-03-12, 19:05)Alexander Etges Wrote: Hello @All of you! Hi Alexander, If you can provide me with good flat images for the patterns, I can make them using texture mapping. That should be no problem. RE: Texture mapping - Alexander Etges - 2019-03-14 (2019-03-12, 22:07)Jaco van der Molen Wrote: Hi Alexander, Sounds good! https://drive.google.com/drive/folders/1tU2U2YJLgyF9o9y_O_fjIcoKNTeddhxv?usp=sharing I hope the pics are okay! RE: Texture mapping - Jaco van der Molen - 2019-03-24 (2019-03-14, 20:56)Alexander Etges Wrote: Sounds good! OK, these seem OK. I'll give it a try. RE: Texture mapping - Damien Roux - 2019-03-25 (2019-03-24, 20:40)Jaco van der Molen Wrote: OK, these seem OK. I'll give it a try. Check the tracker, as I'm curently working on those particular ones. RE: Texture mapping - Jaco van der Molen - 2019-03-26 (2019-03-25, 19:22)Damien Roux Wrote: Check the tracker, as I'm curently working on those particular ones. OK, Damien. Do you need my (vector) drawings? I've done only a few now. RE: Texture mapping - Damien Roux - 2019-03-27 (2019-03-26, 10:09)Jaco van der Molen Wrote: OK, Damien. Do you need my (vector) drawings? I've done only a few now. As the patterns are not complex, I should be OK. All the patterned parts of Brickheadz SDCC2016 are on the tracker BTW. |
