Sloped brick with Batman logo - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Sloped brick with Batman logo (/thread-21971.html) |
Sloped brick with Batman logo - Reuben Pearse - 2017-01-04 I'm looking for an LDraw version of this part: http://picclick.com.au/Lego-batman-slope-182163186812.html I found this part (973pb0a.dat) that has the Batman logo, but how do I extract just the Batman logo from the dat file (I was thinking I could just create a sticker part and lay it on top of the slope brick). I also found this sticker part (4297014a.dat), but the logo is to big for the slope brick - is there a way to easily scale this logo to make it smaller? What's the best tool for selecting/extracting certain parts of an existing part file? (other than Notepad++) RE: Sloped brick with Batman logo - Philippe Hurbain - 2017-01-04 (2017-01-04, 7:53)Reuben Pearse Wrote: What's the best tool for selecting/extracting certain parts of an existing part file? (other than Notepad++)The best tool nowadays is LDPartEditor (http://nilsschmidt1337.github.io/ldparteditor/). For simple tasks like this MLCad can do the trick (but it doesn't allow to cut and paste between two different files so you will probably need a text editor too in the process... RE: Sloped brick with Batman logo - Reuben Pearse - 2017-01-07 Philippe Hurbain (2017-01-04, 7:53)Reuben Pearse Wrote: What's the best tool for selecting/extracting certain parts of an existing part file? (other than Notepad++)The best tool nowadays is LDPartEditor (http://nilsschmidt1337.github.io/ldparteditor/). For simple tasks like this MLCad can do the trick (but it doesn't allow to cut and paste between two different files so you will probably need a text editor too in the process... Thanks Philippe - I used LDPartEditor to extract the logo part and created a new file called "batman_logo_small.dat". I then added this to the part 47753.dat in an attempt to create this part: http://www.bricklink.com/v2/catalog/catalogitem.page?P=47753pb015#T=C&C=11 This brick+sticker is featured in this set: http://brickset.com/sets/7780-1/The-Batboat-Hunt-for-Killer-Croc I guess the sticker part could be "embedded" into the 47753 part to make a new part? Would this then be a new "official" LDraw part? Could you take a look at the sticker alignment on the wedge brick? How close should this be to the surface of the brick? The relevant files are attached |
