LDCad 1.6 Beta 1 (win+linux) - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: LDCad 1.6 Beta 1 (win+linux) (/thread-21955.html) Pages:
1
2
RE: LDCad 1.6 Beta 1 (win+linux) - Roland Melkert - 2017-02-08 (2017-02-08, 20:28)Willy Tschager Wrote: Feature request of the day: I have been thinking about selection depended bin groups but most things I came up with would need (massive amounts) of extra information about parts. But your suggestion of just the same category seems simple enough, maybe in 1.7/2.0 As for preventing to have to go up / switch tab, you could open a second part bin for that. RE: LDCad 1.6 Beta 1 (win+linux) - Owen Dive - 2017-02-12 Hi. I have a small bug to report that I don't recall seeing anywhere else. If I select a part and press Delete, the part is deleted. So far so good. But if I click again (without moving the mouse from the initial select), the editing pin and grid appear as though the deleted part is selected. I can even move this ghost part around using the arrow keys. It also happens if the part is hidden rather than deleted - if you don't move your mouse you can select the hidden part and move it around. I discovered this on version 1.6 Beta 1a, but haven't checked any earlier version. Owen. RE: LDCad 1.6 Beta 1 (win+linux) - Roland Melkert - 2017-02-12 (2017-02-12, 10:39)Owen Dive Wrote: If I select a part and press Delete, the part is deleted. So far so good. But if I click again (without moving the mouse from the initial select), the editing pin and grid appear as though the deleted part is selected. I can even move this ghost part around using the arrow keys. It also happens if the part is hidden rather than deleted - if you don't move your mouse you can select the hidden part and move it around.Zombie parts It has probably been there since forever, don't worry about crashes or something though. Parts are never really deleted just marked so (for undo). Thanks for reporting, I'll fix it for Beta 2. |
