10252 Volkswagen Beetle [Creator] - Printable Version
+--- Thread: 10252 Volkswagen Beetle [Creator] (/thread-21791.html)
10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-09-27
[size=medium][size=large]10252 Volkswagen Beetle [Creator]
[Image: 29842223374_55db5f72b6_c.jpg]
[/size]
[/size]MPD-file (OMR compliant)
Done with LDCad 1.5
Edit 21.10.16: Stickers added. [size=x-large][size=medium][size=large]Thanks to Magnus for generating all stickers![/size][/size]
Unofficial parts and stickers imported into the mpd file via mpd center
[/size]
[size=x-large][size=medium][size=large]Known Errors: None[/size][/size][/size]
RE: 10252 Volkswagen Beetle [Creator] - Philippe Hurbain - 2016-09-28
So nice! Wink
But there is a reference to 10252_towel.dat that's not in mpd?
Otherwise... got in the mood for some patterns!
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/98138p81.dat
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/98138p82.dat
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-09-28
(2016-09-28, 6:51)Philippe Hurbain Wrote: But there is a reference to 10252_towel.dat that's not in mpd?
Fixed the towel issue!
And many thanks for the patterned parts. Just added them to the mpd file.
RE: 10252 Volkswagen Beetle [Creator] - Magnus Forsberg - 2016-09-28
(2016-09-28, 6:51)Philippe Hurbain Wrote: Otherwise... got in the mood for some patterns!
The soda can top is a duplicate of an already made pattern, 98138p0h.dat
Do someone have a good scan of the stickers? I want to complete this model, and make the missing stickers.
RE: 10252 Volkswagen Beetle [Creator] - Niklas Buchmann - 2016-09-28
I noticed the two 45590 axle joiners holding the cooler on the roof are plastic black, they should be rubber black instead.
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-09-29
(2016-09-28, 21:42)Niklas Buchmann Wrote: ... they should be rubber black instead.
Fixed it. Thanks!
RE: 10252 Volkswagen Beetle [Creator] - Niklas Buchmann - 2016-09-29
[Image: 29718261950_7bdeba61b4_b.jpg]LEGO 10252 - Volkswagen Beetle by Niklas-B, auf Flickr
Here's a HQ render of the Beetle, free to use.
[Image: 29432551023_7640b40343_b.jpg]LEGO 10252 - Volkswagen beetle (rear) by Niklas-B, auf Flickr
RE: 10252 Volkswagen Beetle [Creator] - Roland Melkert - 2016-09-30
(2016-09-27, 23:34)Roland Dahl Wrote: [size=medium][size=large]10252 Volkswagen Beetle [Creator][/size][/size]
Very nice renderings.
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=24607
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=t08o2500
are missing for me though.
tip: You might want to consider using submodels for things like the bonnet in the future, it makes posing for HQ rendering alot easier.
RE: 10252 Volkswagen Beetle [Creator] - Willy Tschager - 2016-09-30
Nice rendering - would you share your settings? Pov or Blender?
RE: 10252 Volkswagen Beetle [Creator] - Niklas Buchmann - 2016-09-30
(2016-09-30, 11:59)Willy Tschager Wrote: Nice rendering - would you share your settings? Pov or Blender?
POV-Ray.
I don't have a problem with sharing the settings, it's just that my lg_color.inc file is such a mess that it might not be of much help to others. Anyway, I attached the lg_color.inc and the POV-Ray file for others to take a look at.
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-09-30
Both parts are now correctly imported as unofficial parts into the mpd-file. By mistake I saved these parts not to unofficial parts folder, but to the official parts folder. Seems I have to improve my unofficial parts management system.
I now understand your point regarding the submodels. For the bonnet, the doors and other components I already generated complete groups (not submodels). Here you see for example the upper bonnet group:
[Image: VW_grouped.jpg]
and this is the relevant mpd-file.
BUT: After processing this file with mpd-center for making it OMR compliant, it seems that all groups have vanished somehow!? Here is the same mpd-file after making it OMR-compliant.
Any idea what went wrong?
BTW: The reason that I used groups instead of submodels is that my target was to built the model according to the instructions and the relevant instrcution steps. So for the upper bonnet I grouped main step 170 to 177. The lower bonnet is a submodel within main step 178.
(2016-09-30, 20:26)Roland Dahl Wrote: BUT: After processing this file with mpd-center for making it OMR compliant, it seems that all groups have vanished somehow!? Here is the same mpd-file after making it OMR-compliant.
MPDCenter makes comments out of metas it doesn't know about this messes with the group definitions. I think it does that to force the modern comments but it should leave 0 !* lines alone imho)
You can fix it by doing a search/replace in e.g. notepad. Replace "0 // !LDCAD GROUP" with "0 !LDCAD GROUP"
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-10-01
(2016-09-30, 20:46)Roland Melkert Wrote: You can fix it by doing a search/replace in e.g. notepad. Replace "0 // !LDCAD GROUP" with "0 !LDCAD GROUP"
Thanks, that worked! Now the groups haved returned to the mpd file.
RE: 10252 Volkswagen Beetle [Creator] - Michael Klein - 2016-10-01
Such a nice model. I wished James Jessiman could enjoy today what he gave to us. Without him my project Renderbricks would not exist.
[Image: 29412398793_2aa88d8820_h.jpg]LEGO® Creator 10252 Volkswagen Beetle by Renderbricks, auf Flickr
[Image: 29411593064_85c8349008_h.jpg]LEGO® Creator 10252 Volkswagen Beetle by Renderbricks, auf Flickr
RE: 10252 Volkswagen Beetle [Creator] - Merlijn Wissink - 2016-10-01
Great renders as always! I took a look through your Flickr and there were a lot I had not seen yet. Great work!
I don't want to nag, but a while ago you 'promised' (not actually promised, but I don't know a better word) a render at a 3440x1440 resolution which I can use as a wallpaper  Angel
RE: 10252 Volkswagen Beetle [Creator] - Michael Klein - 2016-10-02
(2016-10-01, 15:52)Merlijn Wissink Wrote: Great renders as always! I took a look through your Flickr and there were a lot I had not seen yet. Great work!
You want the Beetle in that res? Or something else? ;-)
RE: 10252 Volkswagen Beetle [Creator] - Merlijn Wissink - 2016-10-02
(2016-10-02, 9:21)Michael Klein Wrote: You want the Beetle in that res? Or something else? ;-)
To be honest, I have no idea what, I can't choose.
All your renders just looks so nice, the Beetle, the Porsche, the Nexo Knights minifigure, the spaceships.
Just make something you personally like/is easy for you and I'll probably like it anyway Tongue
EDIT: now that I think of it, this 'ultrawide' resolution might be perfect for a collection of models, a series or something like that... Just thinking out loud.
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-10-03
(2016-09-28, 21:22)Magnus Forsberg Wrote: Do someone have a good scan of the stickers? I want to complete this model, and make the missing stickers.
I'm curious: How things are going? Any progress regarding your search for a good scan? Hopefully the Beetle Sticker Project is not on hold ....
RE: 10252 Volkswagen Beetle [Creator] - Magnus Forsberg - 2016-10-03
(2016-10-03, 10:26)Roland Dahl Wrote: I'm curious: How things are going?
I've been busy re-working old part at the Part Tracker, but I'll move these stickers to the top of my To-do-list.
I think I can work on the picture of the sticker in this review at The Brick Fan.
Which license plate do you prefer?
(2016-10-03, 15:17)Magnus Forsberg Wrote: I've been busy re-working old part at the Part Tracker, but I'll move these stickers to the top of my To-do-list.
Great! But please slow down, there is no need to hurry.
I would prefer the WOB plate which means Wolfsburg. Wolfsburg is home respectively headquarter of Volkswagen.
RE: 10252 Volkswagen Beetle [Creator] - Magnus Forsberg - 2016-10-10
15 stickers done. Two more to do.....
All of the stickers are now done. Still needs some postprocessing, but I'll upload them all tomorrow
RE: 10252 Volkswagen Beetle [Creator] - Magnus Forsberg - 2016-10-13
All of the stickers for the Beetle are now available at the Part Tracker
[Image: 10252-stickers2.png]
RE: 10252 Volkswagen Beetle [Creator] - Roland Dahl - 2016-10-13
(2016-10-13, 20:10)Magnus Forsberg Wrote: All of the stickers for the Beetle are now available at the Part Tracker
Wow, that's great, thank you so much. But I think the honor is yours to complete the model respectively to add the stickers to the model and post it. Please feel free.
RE: 10252 Volkswagen Beetle [Creator] - Magnus Forsberg - 2016-10-14
I'm very hesitant to the idea of making my models available or OMR compliant, so I've never learnt how to work with MPDCenter.
And I don't like, or understand, what LDCad made with my file.
I don't want to mess up your file, so here is a copy of my own version. With stickers.
.mpd   10252.mpd (Size: 295.43 KB / Downloads: 16)
The real fun is to assemble the model yourself.
