Missing Ldraw Colors - Printable Version
+--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html)
+--- Thread: Missing Ldraw Colors (/thread-21749.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
RE: Missing Ldraw Colors - Sven v. Beuningen - 2016-10-22
Next one
[Image: 4229354.jpg]
Brick 2x4
My own Data
Lego ID: 219
Lego Name: LILAC
MY guessed name: Lilac
http://www.ldraw.org/article/547.html
No match found
http://wiki.ldraw.org/index.php?title=User:Owen_Burgoyne/LDraw_Colour_Comparison_Chart
Lego ID: 219
Ldraw Name: Violet
Lego Name: Lilac
RGB: #564E9D
http://www.peeron.com/inv/colors
No match found
http://www.bricklink.com/message.asp?ID=868566
Lego ID: 219
Lego Name: Lilac
http://rebrickable.com/colors
Lego ID: 1009
Ldraw ID: 110
Bricklink ID: 43
Lego Name: LILAC
Rebrickable Name: Violet
RGB: #4354A3
http://swooshable.com/parts/colors
Lego ID: 219
Ldraw ID: na
Bricklink ID: 73
Bricklink Name: Lilac
Lego name: Lilac
RGB: #564E9D
We might have a conflict here, because Rebrickable mentioned 110 as Ldraw ID whis is "Bright bluish violet". I also have 110 as Lego ID Bright bluish violet, so maybe 219 is something similar, but at least from TLG point of view different.
So Long
Sven
RE: Missing Ldraw Colors - Willy Tschager - 2016-10-24
The main problem is that we have a total mismatch between Lilac, Pink, Violet and Purple, but it cannot be solved without breaking the links to BL. I would therefore go with BLs "Medium Violet"
RE: Missing Ldraw Colors - Sven v. Beuningen - 2016-10-25
(2016-10-24, 19:00)Willy Tschager Wrote: The main problem is that we have a total mismatch between Lilac, Pink, Violet and Purple, but it cannot be solved without breaking the links to BL. I would therefore go with BLs "Medium Violet"
May I asked why it would be a big issue to break/rework the links with BL if we could clean up stuff?
So Long
Sven
RE: Missing Ldraw Colors - Willy Tschager - 2016-10-25
So Long
Sven
Because many use the LDraw System of Tools to prototype and the resulting parts list as shopping list for BL. It wouldn't make much sense to clean up stuff for the sake that we know the fan created charts are wrong and we know better.
RE: Missing Ldraw Colors - Sven v. Beuningen - 2016-10-27
Ok, got it. Then let's go with Medium  Violet. What about the colors? Shall we go with Swooshable #564E9D?
So Long
Sven
RE: Missing Ldraw Colors - Willy Tschager - 2016-10-28
(2016-10-27, 18:52)Sven v. Beuningen Wrote: Ok, got it. Then let's go with Medium  Violet. What about the colors? Shall we go with Swooshable #564E9D?
So Long
Sven
Yepp, do so.
RE: Missing Ldraw Colors - Sven v. Beuningen - 2016-10-29
So Long
Sven
Yepp, do so.
Here it is:
LEGO color: 219 | Lilac => Ldraw: 219 | [color=black]Medium[/color] Violet  VALUE[color=black] #564E9D -[/color] EDGE #333333
Next one
[Image: 6051422.jpg]
Lattice Plate 1x2 "No. 1000"
My own Data
Lego ID: 336
Lego Name: SILVER INK
MY guessed name: Silver Ink
No match found
Lego ID: na
Ldraw Name: Metallic Silver
Lego Name: Silver Ink
RGB: na
No match found
Lego ID: 336
Lego ID: 1003
Ldraw ID: 80
Bricklink ID: 67
Rebrickable Name: Metallic Silver
RGB: #A5A9B4
Lego ID: 336
Ldraw ID: na
Bricklink ID: na
Bricklink Name: na
Lego name: Silver Ink
RGB: #F7F7F7
I think this is quiet a challenge. We have a free Ldraw ID, but a mismatch with the names. Rebrickable points out "Metallic Silver (Ldraw 80)" , but this is already taken by (LEGO ID 315 "Silver Metallic").
We could create a new color or map LEGO ID 336 also to LDraw ID 80.
So Long
Sven
RE: Missing Ldraw Colors - Philippe Hurbain - 2016-10-29
What I don't understand is that we have 3 different LEGO IDs (depending on source) for this color ??? (336/219/1003)
RE: Missing Ldraw Colors - Sven v. Beuningen - 2016-10-30
(2016-10-29, 18:18)Philippe Hurbain Wrote: What I don't understand is that we have 3 different LEGO IDs (depending on source) for this color ??? (336/219/1003)
As far as I know 1003 is a ID which is taken by rebrickable, because they didn't know the number. I did not get any number higher than 999 from TLG.
336 is Silver Ink from TLG
219 is mistake from the last color. I'll just correct it.
So Long
Sven
