Missing Ldraw Colors - Printable Version
+--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html)
+--- Thread: Missing Ldraw Colors (/thread-21749.html)
Pages: 1 2 3 4
RE: Missing Ldraw Colors - Sven v. Beuningen - 2017-06-07
(2017-06-06, 20:22)Merlijn Wissink Wrote: Does this color exist in LDraw? If not, would it even be necessary to add it?
Lego ID: 220
Lego Name: Light Lilac
Here's a tiny bit of information on Brickset.
It seems to be a pretty rare color.
The only thing I know is:
LEGO ID: 220
LEGO Name: Lgh. Lilac
I haven't found a single part which uses this color, but my check is from several month ago.
So Long
Sven
RE: Missing Ldraw Colors - Ryan Howerter - 2017-07-27
(2016-12-19, 16:28)Magnus Forsberg Wrote: Based on the picture from Ryan H. I would say it ought to be like this:
334 should be mapped to new code 300 - Metallic_Copper
335 should be mapped to 82 - Metallic_Gold
336 should be mapped to 80 - Metallic_Silver
It looks to me as a "flat" metallic paint. Not a mirrorlike chrome plated surface.
I don't understand why Ryan has placed a Chrome_Gold crown and a Chrome_Silver lightsabre next to the three painted parts.
Maybe to illustrate the confusion? Two different surfaces on the same code?
That's because Lego has used "335 Gold Ink" to refer to both Chrome Gold and Metallic Gold coatings.  From what I've seen, Gold Ink is sort of a catch-all for any gold coating now. Same with 336 Silver Ink.
RE: Missing Ldraw Colors - Magnus Forsberg - 2017-12-12
(2017-03-03, 16:54)Willy Tschager Wrote: Sorry for the delay. Use the rebrickable color which is closer to what I measured with PS and 59425e for the edge.
Hello Sven and Willy
The Rebrickable colour code (#96709F) is identical to what we already have at CODE 44 "Trans_Bright_Reddish_Lilac"
I think this must be corrected.
May I suggest something like #C281A5 instead.
RE: Missing Ldraw Colors - Willy Tschager - 2017-12-14
Fine with it.
RE: Missing Ldraw Colors - Magnus Forsberg - 2017-12-14
(2017-12-14, 12:36)Willy Tschager Wrote: Fine with it.
Could you please calc a correct colour for the edges? It's a transparent colour, and should have coloured edges.
I was never able to replicate the values you created.
RE: Missing Ldraw Colors - Willy Tschager - 2017-12-15
Please use #82566E. The conversation is easy. Reduce the Brightness in a HSB room by 25%:
http://www.workwithcolor.com/color-converter-01.htm
* The space in front of // LEGOID 309 / 336 - Metalized Silver/Silver Ink and // LEGOID 300 / 334 - Copper Drum Lacq/Copper Ink has been corrected.
* The LDCOnfig.ldr uses "Gray" because of https://www.merriam-webster.com/dictionary/gray (variants: or less commonly grey).
Here is the latest update:
.ldr   LDConfig.ldr (Size: 28.45 KB / Downloads: 5)
RE: Missing Ldraw Colors - Magnus Forsberg - 2017-12-15
(2017-12-15, 13:04)Willy Tschager Wrote: Please use #82566E. The conversation is easy. Reduce the Brightness in a HSB room by 25%:
Thank you,
My antivirus blocks that site... Dodgy   Any other online site that can do the same simple adjustment?
Why do the offical colour file use a different spelling than what we are forced to use in the description of a patterned part?
DatHeader corrects "Gray" too "Grey" since it is american english.
RE: Missing Ldraw Colors - Willy Tschager - 2017-12-16
Thank you,
Try https://www.rapidtables.com/convert/color/ or search for "Conversion HEX to HSB/HSV".
Guess the Gray/Grey dilemma has to be forwarded to a native.
RE: Missing Ldraw Colors - Magnus Forsberg - 2017-12-16
(2017-12-16, 9:46)Willy Tschager Wrote: Reduce the Brightness in a HSB room by 25%
I finally got it working.
Theres a big difference in "reduce by 25%" and "reduce by 25 percent points"....
RE: Missing Ldraw Colors - Chris Dee - 2017-12-20
(2017-12-14, 17:23)Magnus Forsberg Wrote: Could you please calc a correct colour for the edges? It's a transparent colour, and should have coloured edges.
When (and why) did we switch to American English in this file? In appreciation of James' work we prefer Australian English. All my references indicate that the preferred Australian spelling is 'Grey'. Merriam-webster is American English.
RE: Missing Ldraw Colors - Joshua Delahunty - 2018-01-27
Lego ID: 220
LEGO ID: 220
So Long
Sven
FWIW, 220 is generally a DUPLO or CLICKITS color, though (up to) two SYSTEM elements came in the color: Design 43802 (as shown on Brickset) and 33230 (I find Item references, but not necessarily sets that used the Item)
     -- joshua
RE: Missing Ldraw Colors - Max Martin Richter - 2018-02-25
(2017-02-08, 19:33)Willy Tschager Wrote: No.
                                                       LDraw:  62 | Chrome_Green - VALUE #3CB371 - EDGE #007735 - Material CHROME
LEGO color: 186 | Metallic Dark Green => LDraw: 186 | Metallic_Dark_Green - VALUE #008E3C - EDGE #333333 - Material PEARLESCENT
Material must be Metal. It's alreadey fixed in the first post.
RE: Missing Ldraw Colors - Willy Tschager - 2018-03-03
Max has cross-checked the color table in the last days and found a mis-match of 383 and 87. With these pics as reference:
https://www.flickr.com/photos/126975831@N07/15801189140/
https://www.flickr.com/photos/126975831@N07/17768155498/
the correct match between LEGO and LDraw colors is:
0 // LEGOID 309 / 336 - Metalized Silver / Silver Ink
0 !COLOUR Chrome_Silver CODE 383 VALUE[color=black] #E0E0E0[/color] EDGE CHROME
0 // LEGOID 298 / 336 - Cool Silver Drum Lacq / Silver Ink
0 !COLOUR Metallic_Dark_Grey CODE 87 VALUE EDGE METAL
Attached the correct:
.ldr   LDConfig.ldr (Size: 28.79 KB / Downloads: 2) .
RE: Missing Ldraw Colors - Magnus Forsberg - 2018-03-03
(2018-03-03, 7:22)Willy Tschager Wrote: 0 // LEGOID 309 / 336 - Metalized Silver / Silver Ink
Oh, no. Not this again. In my opinion, this is not correct.
I agree on that LEGOID 309/336 is Ldraw CODE 383 "Chrome_Silver"
But connecting LEGOID 298/336 to Ldraw CODE 87 is wrong.
IMO, LEGOID 298/336 should be connected to Ldraw CODE 80 instead.
LDraw CODE 87 "Metallic_Dark_Grey" might be connected to LEGOID 148, but only in RGB-values. Not in material.
IMO, we are missing a LEGO name of the metallic dark grey colour paint.
We only have the name of the metallic dark grey plastic, LEGOID 148 "Dark Grey Metallic"
RE: Missing Ldraw Colors - Steffen - 2018-03-05
is this the resurrection of
https://forums.ldraw.org/thread-214-post-323.html#pid323
