Noise in render of transparent object - Printable Version
+--- Thread: Noise in render of transparent object (/thread-21730.html)
Noise in render of transparent object - Bas - 2016-08-26
Hi Guys,
I hope somebody can give me a tip how to remove noise from a POV-ray render of a glass object.
I made the model in LDD, exported it in LDD and converted the model with LDview to the POV format.
I used ambient lighting (3 standard light sources changed to ambient lights).
But as you can see the transparent train window shows noise.
Does anyone have a tip for me to reduce/remove the noice?
Thanx!
RE: Noise in render of transparent object - Damien Roux - 2016-08-28
Does this part have a pov equivalent ? If yes, it is maiby because there are coincident surfaces which make noise in povray.
Solution would be not to use the LGEO equivalent or to create your own without the problem.
RE: Noise in render of transparent object - Bas - 2016-08-28
(2016-08-28, 13:33)Damien Roux Wrote: Does this part have a pov equivalent ? If yes, it is maiby because there are coincident surfaces which make noise in povray.
Hi Damien,
Thanks for your response. I checked the /lg/ directory and there is a equivalent: lg_4036.
How do I bypass this LGEO version?
(2016-08-28, 19:12)Bas Wrote: Hi Damien,
Remove this in your LGEO.xml file :
        <Element>
            <LDrawFilename>4036.dat</LDrawFilename>
            <POVName>lg_4036</POVName>
            <POVName Alternate="Clear">lg_4036_clear</POVName>
            <Dependency>LGDefs</Dependency>
            <POVFilename>lg_4036.inc</POVFilename>
            <MatrixRef>LGEOTransform</MatrixRef>
        </Element>
        <Element>
        </Element>
Will do! Thanks! I will let you know if it works!
RE: Noise in render of transparent object - Bas - 2016-08-29
It worked!
Thanx Damien!
RE: Noise in render of transparent object - Michael Horvath - 2016-09-16
Clear plastic parts look too "milky" in LGEO/POV output IMO.
RE: Noise in render of transparent object - Damien Roux - 2016-09-16
(2016-09-16, 5:59)Michael Horvath Wrote: Clear plastic parts look too "milky" in LGEO/POV output IMO.
Try using radiosity instead of classic lightning.
RE: Noise in render of transparent object - Michael Horvath - 2016-09-25
Yes, I am using LGEO. Here's a good example:
https://www.flickr.com/photos/108839565@N04/29469026205/in/dateposted-public/
You can hardly see through the glass.
RE: Noise in render of transparent object - Orion Pobursky - 2016-09-26
Looks like I need to revive my lugnetcolors.inc file
Also +1 for radiosity. Transparency is rendered way better
RE: Noise in render of transparent object - Michael Horvath - 2016-09-26
I am using radiosity.
RE: Noise in render of transparent object - Damien Roux - 2016-09-26
Try to get an updated lg_colors.inc file. Try the ldraw AIOI.
(2016-09-26, 6:26)Damien Roux Wrote: Try to get an updated lg_colors.inc file. Try the ldraw AIOI.
I could only find "lg_color.inc" not "lg_colors.inc".
What is the modification date for your copy of this file? The changelog for the one I'm using says, "2013-05-27 Owen Burgoyne altered reflection for transparent parts" for the latest version.
Yes, it is that one lg_color.inc
Could you post it here, I will have a look and compare it to mine.
(2016-09-26, 8:51)Damien Roux Wrote: Yes, it is that one lg_color.inc
Here it is.
