LDCad crashes when I use part 6141 - Printable Version
+--- Thread: LDCad crashes when I use part 6141 (/thread-21552.html)
LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-05-31
When I use part 6141 (plate 1x1 round) LDCad crashes on my machine @ home (old laptop with low specs).
This is an alias ("~moved to" or "=moved to") parts. Isn't that strange too?
Using 4073.dat everything runs fine.
I know there must be more parts that cause crashes.
RE: LDCad crashes when I use part 6141 - Merlijn Wissink - 2016-05-31
4073 is actually the moved to part. It's moved to 6141.  Wink
Both work fine in my LDcad (both 1.5 and 1.6) though. I've never had a certain part crash LDcad
RE: LDCad crashes when I use part 6141 - Roland Melkert - 2016-05-31
(2016-05-31, 18:16)Jaco van der Molen Wrote: When I use part 6141 (plate 1x1 round) LDCad crashes on my machine @ home (old laptop with low specs).
Is this in the last 1.5 version, as it reminds me of the bug
- [PartBin] Alias parts having shadow content will no longer potentially crash the program when rendered in a bin cell.
I fixed in 1.5 beta 1a
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-01
Right. I work with the normal 1.5 version, not beta.
And, loading LDCad the round 1x1 plate is not currently visible in the partbin, only in the model.
The strange thing is that when loading a model all these blue and green + signs are visible while rendering the model.
Only where the round 1x1 plate is going to be, it looks very different. Seems no + signs but blue dots or something. I'll try to make a screenshot before the crash to illustrate this later today.
And the crash does not happen with the same model on my PC at work.
(2016-05-31, 18:22)Merlijn Wissink Wrote: 4073 is actually the moved to part. It's moved to 6141.  Wink
Ah, right. My mistake :-)
RE: LDCad crashes when I use part 6141 - Roland Melkert - 2016-06-01
(2016-06-01, 5:46)Jaco van der Molen Wrote: And, loading LDCad the round 1x1 plate is not currently visible in the partbin, only in the model.
Blue crosses are files being loaded/parsed.
Green crosses are files (waiting to) being prepped for rendering.
Yellow crosses are files of which the render prep failed, maybe the gpu is out of memory or something, The logfile might give some more insight.
Red crosses are missing files.
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-02
Here is what it looks like where the 1x1 round plates should be using 6141:
.png   1x1roudPlates.png (Size: 48.6 KB / Downloads: 84)
A few parts render complete then crash.
RE: LDCad crashes when I use part 6141 - Roland Melkert - 2016-06-02
(2016-06-02, 17:53)Jaco van der Molen Wrote: A few parts render complete then crash.
Could you send me the logfile(s) as it should indicate which part/file it was working on during the crash.
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-03
(2016-06-02, 19:22)Roland Melkert Wrote: Could you send me the logfile(s) as it should indicate which part/file it was working on during the crash.
OK, I'll clear the logs and start a fresh one.
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-08
Sorry Roland, didn't have time yet to reproduce the crash and send the logs. Will do this a.s.a.p.
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-28
LDCad keeps crashing here (old laptop). Now in a model without 6141.
Though 6141 is mentioned in the log?
Here is that log, Roland. Perhaps you can take a look?
RE: LDCad crashes when I use part 6141 - Roland Melkert - 2016-06-28
(2016-06-28, 17:53)Jaco van der Molen Wrote: LDCad keeps crashing here (old laptop). Now in a model without 6141.
I'm afraid the log isn't very helpful. Are you sure you are using the latest ldraw library? If not which version are you using.
Also the used model might shed some light on it (mail it directly if you don't want to share it).
I'll take a closer look in a couple of days.
OK, I am pretty sure I have the latest update, but might reinstall.
I'll mail you the model.
(2016-06-28, 19:36)Jaco van der Molen Wrote: OK, I am pretty sure I have the latest update, but might reinstall.
I think you are using the 1402 library as I got 1.5 to crash looking for 6143 in the part bin when using the 1402 complete.zip as main lib Smile
It seems the above mentioned alias in part bin bug isn't fixed after all. I'll reopen it.
edit: upgrading to the 1502 lib should fix the issue too.
RE: LDCad crashes when I use part 6141 - Jaco van der Molen - 2016-06-29
OK, thanks for finding out. As said, I am unsure I had the latest update.
I have 4 machines I work with LDraw on, so I probably thought I updated them all, but forgot my old laptop.
I'll install and let you know if it solves the problem.
