[LDPartEditor] 0.8.15 Beta Released - Printable Version
+--- Thread: [LDPartEditor] 0.8.15 Beta Released (/thread-21526.html)
Pages: 1 2 3 4
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Philippe Hurbain - 2016-05-26
Vertex merge with ctrl-W / ctrl-E is an awesome tool to reduce a mesh in a controlled way. So...
Wish of the day: when selecting several vertices with a marquee, it would be nice if the last vertex enclosed in the marquee became last vertex in selection so that ctrl+E merges all vertices onto this last vertex. That would be a great time saver!
Otherwise, never used so far the merge to nearest edge/face functions. Now I did, and I can say it's an awesome tool to coerce a random mesh to fit a primitive (eg. LDD wig mesh onto a LDraw head)
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Willy Tschager - 2016-05-27
(2016-05-23, 18:45)Philippe Hurbain Wrote: Bug: when you mirror a selection
How is this done?
Feature request of the day:
Since it is now possible to select in the line numbers I'd like that a double click shows the selection also in the 3D editor.
Bug:
Selecting in the line numbers and hitting "Selection in 3D view" most often in the 3D also the neighbour triangle/quad is selected.
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Philippe Hurbain - 2016-05-27
How is this done?
Merge/split -> scale selection -> -1 coefficient.
Quote:Since it is now possible to select in the line numbers I'd like that a double click shows the selection also in the 3D editor.
It would be great if line selection was more consistent with other Windows selections. Currently shift + line number click simply select that line number only, and ctrl+click on two separated lines selects all the lines in-between. It would be better if ctrl+click on different lines selected all of those lines only (even if separated) and shift+click allowed for a range of lines selection.
Quote:Selecting in the line numbers and hitting "Selection in 3D view" most often in the 3D also the neighbour triangle/quad is selected.
Seems to be related to the fact that clicking on line number also selects line separator.
Question of the day: is it really necessary to open a blank "new.dat" file at LDPC startup? 99.99% of the time the first thing I do is to close it and I have to tell that no, I don't want to save it! At least, it shouldn't be tagged as modified unless really modified...
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Philippe Hurbain - 2016-05-28
Bug report: Quick fixing of scaled 48\primitives messes up the primitive name. 48\prim.dat is converted to 48prim.dat
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Willy Tschager - 2016-05-30
How is this done?
THX,
PS. Would prefer LDPC's icon instead ;-)
Bug:
the black 3s and 4s were Selected with ...Connected... and ...with Same Color:
performing a Cut also some lines with color 16 got cut out:
and in addition the cut could not be undone.
RE: [LDPartEditor] 0.8.15 Beta Released (randomise colours / bug fix) - Willy Tschager - 2016-06-01
* I would love if the real and user name could be copied from the options to the header dialog
* I find the dialog far from ideal: first I do not understand why it appends to the file focused in the 3D editor though a header is clearly a text thing, second it gets appended to the bottom even though I have place the cursor at the top - and here comes into play that it focuses on the 3D
* Once again I also would love if the file gets closed in both, text and 3D editor when I close them in one or the other editor
