ldglite 1.3.1 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: ldglite 1.3.1 (/thread-21463.html) |
ldglite 1.3.1 - Don Heyse - 2016-04-10 So, after 12 years of dithering, I've finally incorporated the ldrawini sourceforge code into ldglite so it can use a part search strategy compatible with ldview and l3p. The new code is in the ldglite CVS and github repositories. And for now, I've built a pair of new Windows executables. One is a regular ldglite release, and the other is a special build that automatically uses the new -2g,2x command line setting for any offscreen rendering. The new setting renders a cleaner antialiased image. That might be useful as a drop in replacement for ldglite in lpub4 or LPub3D. You can find it at the same old ldglite.sourceforge.net location. If I can convince myself that some version of lpub works on Macs,then I'll also try to crank out a new OSX build. |
