Part snapping plate 1x1 round in LDCad is difficult? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: Part snapping plate 1x1 round in LDCad is difficult? (/thread-21275.html) |
Part snapping plate 1x1 round in LDCad is difficult? - Jaco van der Molen - 2016-03-22 Is it me and is this a silly question or does anyone else experience difficulty placing a 1x1 plate round in LDCad with part snapping turned on? Dragging this part from the part bin to the model almost never finds a connection or a strange one for me. I am having serious trouble placing this part in any model while other (small) parts (like a normal 1x1 plate) work perfectly fine. My € 0,02... Re: Part snapping plate 1x1 round in LDCad is difficult? - Merlijn Wissink - 2016-03-22 1x1 round plate also behaves a bit weird for me. I'd call it 'sensitive'. When I look at my model from a steep angle, it very often jumps between on top of the plate/brick I try to attach it and under the plate/brick. When I look at my model from a lower angle, everything works fine and I can just place it on the of the other part. Re: Part snapping plate 1x1 round in LDCad is difficult? - Jaco van der Molen - 2016-03-22 See illustrated screencapture here: http://youtu.be/wJPeyMBwSV8?hd=1 (might take a few minutes more to be public, just recorded and uploaded) Re: Part snapping plate 1x1 round in LDCad is difficult? - Philippe Hurbain - 2016-03-22 Seems indeed to be a bit more picky than even the similar 1x1 round with stud hole. Re: Part snapping plate 1x1 round in LDCad is difficult? - Jaco van der Molen - 2016-03-22 I see. But why? Or is it not that interesting? ;-) Re: Part snapping plate 1x1 round in LDCad is difficult? - Roland Melkert - 2016-03-22 It's probably caused by the whole outer shape having a single snap info (so it also snaps into beam holes). The shape/size of that info (bounding box) makes it more likely to 'win' the connection tests. I'll see if I can improve that behavior somehow. If it really bothers you you could replace the outer shape by just a simple stud one. |
