[MPDCenter] - Bugs and Improvements - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: [MPDCenter] - Bugs and Improvements (/thread-21039.html) |
[MPDCenter] - Bugs and Improvements - Damien Roux - 2016-03-07 Hi there, While OMRizing my set collection I found a few "bugs" in MPDCenter. To reproduce, use the file attached. Here is what I do: Right click on 1714 - Surveillance Scooter.ldr -> Set Name: entry to "Surveillance Scooter.ldr" Right click on the renamed Surveillance Scooter.ldr -> Change description from file name. Now I want to edit the header : I set everything in the Header dialog, click "Build new header" and "Apply". "Do you want to copy athor etc to all other ldr in this mdp?" -> Yes "Are you sure to copy the below header data to all .ldr files in this mpd-file?" -> Yes "Should I try to rename now all files for OMR conformity?" -> Yes Now comes the bugs: The ldr "Spaceship - Rocket 2 - Light.ldr" got renamed to "1714 Rocket 2Light", instead of the desired "1714 - Spaceship - Rocket 2 - Light.ldr" It's losing the .ldr, the "Spaceship" and some spaces. I would say this happen if the name has more than one time the "-" character. The description of the ldr "1714 - Spaceship - Rocket 1.ldr" is now "1714 - Spaceship - Rocket 1" instead of the desire "Spaceship - Rocket 1". It's keeping the set number. I would say this happen if the name has only one "-" character. The header is not the same everywhere, the first ldr shows empty lines above and under the !THEME statement while the other subfiles don't. I would put those empty line everywhere to keep the same formatting and also because I find it better for readability. Now some suggestions: Could we have an option on right clicking a ldr to move it directly above or under a certain ldr? As MPD center rechecks the OMR conformity each time I click "Up" or "Down" it take ages to move files on large sets. In order to clean up the file, would it be possible to have always 2 empty lines between ldr files. Meaning that it should remove the existing lines a the end of a ldr whatever how many there are, and only add 2 empty lines. Re: [MPDCenter] - Bugs and Improvements - Philippe Hurbain - 2016-03-08 Looks like you forgot the attachment... Re: [MPDCenter] - Bugs and Improvements - Damien Roux - 2016-03-08 Corrected. Thanks. Re: [MPDCenter] - Bugs and Improvements - Merlijn Wissink - 2016-03-09 I've also got a little bug: I've turned backup saving off, which works when I save the file by pressing the save button. When I try to close MPDcenter, but I have unsaved changes, it gives a warning and asks if I want to save the model before closing. When I tell it to do so, it saves the model and a backup file, even though I turned that off. Not a big deal, but I'd thought I report it anyway
Re: [MPDCenter] - Bugs and Improvements - Michael Heidemann - 2016-03-14 I have read you post and will come back with a qualify statement. At present I do not have time to do so. |
