WeDo 2.0 electronics - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: WeDo 2.0 electronics (/thread-20686.html) |
WeDo 2.0 electronics - Jetro de Château - 2016-02-17 Do any of you have the new WeDo 2.0 set? I'd love to have LDraw files for the new electronics. (All the other elements appear to be in the LDraw tracker already) Particularly I'm interested in the 19071 hub and the 21980 motor (the motor is very similar to the PF M motor, but it only has 3 pin holes at the front and 4 studs at the top). Much less important are the other elements: 20841tilt sensor 20844 motion sensor As far as I can tell those are identical to the sensors from WeDo 1. However, these elements also use new cables (6 wires) and connectors. Re: WeDo 2.0 electronics - Philippe Hurbain - 2016-02-18 Unfortunately no, I don't have it RE: WeDo 2.0 electronics - Amos Glenn - 2016-05-06 (2016-02-18, 8:08)Philippe Hurbain Wrote: Unfortunately no, I don't have it What would it take to get this done? I'm a user, but wouldn't know where to start drawing these pieces. I'd consider even paying someone to create and share the new WEDO 2 pieces. Not sure how to go about this.... RE: WeDo 2.0 electronics - Gerald Lasser - 2016-05-06 (2016-05-06, 16:27)Amos Glenn Wrote:(2016-02-18, 8:08)Philippe Hurbain Wrote: Unfortunately no, I don't have it Do you have those pieces? The problem is I cannot find pictures from other angles than the official Lego pictures. Especially hires of the sockets would be interesting. What I find difficult to judge right now is the height of the motor, i.e. at how many plates are the studs above the bottom? That would help for mock-ups already. RE: WeDo 2.0 electronics - Amos Glenn - 2016-05-07 (2016-05-06, 21:50)Gerald Lasser Wrote:(2016-05-06, 16:27)Amos Glenn Wrote:(2016-02-18, 8:08)Philippe Hurbain Wrote: Unfortunately no, I don't have it I do have the pieces. And I'd be happy to provide whatever images would be helpful. What's the best way to share them with you (or with anyone interested)? RE: WeDo 2.0 electronics - Gerald Lasser - 2016-05-07 (2016-05-07, 3:35)Amos Glenn Wrote: I do have the pieces. And I'd be happy to provide whatever images would be helpful. You can link them in here, post them on some image sharing site (e.g. brickshelf, dropbox, etc.) I sent you my email in a PM Edit: you have PMs disabled, just add a dot between first and last and add gmx dot at as the domain RE: WeDo 2.0 electronics - Viacheslav - 2016-05-08 (2016-05-07, 21:33)Gerald Lasser Wrote:(2016-05-07, 3:35)Amos Glenn Wrote: I do have the pieces. And I'd be happy to provide whatever images would be helpful. wedo 2.0 SmartHub & motor fotos https://onedrive.live.com/redir?resid=F95FE6E616AD13DB!28967&authkey=!AKfLQwFhlSI6mEQ&ithint=folder%2c RE: WeDo 2.0 electronics - Philippe Hurbain - 2016-05-08 [quote pid='21795' dateline='1462710830'] wedo 2.0 SmartHub & motor fotos https://onedrive.live.com/redir?resid=F95FE6E616AD13DB!28967&authkey=!AKfLQwFhlSI6mEQ&ithint=folder%2c [/quote] Sorry, I should have updated this thread. I got WeDo2 and am actively working on the parts. Connectors, wires and sensors are done, as well as hub top (and battery case is almost completed too). Currently working on motor. Actually I delayed posting on PT because I was still hoping to get real part numbers from LEGO (only got those from hub as it's easy to open)... but it may take a bit more time. RE: WeDo 2.0 electronics - Haibing Zhang - 2016-05-09 (2016-05-08, 17:07)Philippe Hurbain Wrote: [quote pid='21795' dateline='1462710830'] Sorry, I should have updated this thread. I got WeDo2 and am actively working on the parts. Connectors, wires and sensors are done, as well as hub top (and battery case is almost completed too). Currently working on motor. Actually I delayed posting on PT because I was still hoping to get real part numbers from LEGO (only got those from hub as it's easy to open)... but it may take a bit more time. [/quote] WeDO 2.0 45300套装中的LPF2 SMART HUB 2 I/O 4X8X3 External IDs: Rebrickable ID: 19071 LDraw ID: 19071 BrickLink ID: 19071 BrickOwl ID: 686750 Peeron ID: 19071 LEGO Design ID: 19071 Element ID: 6096146 LPF2.0 MEDIUM MOTOR External IDs: Rebrickable ID: 21980 LDraw ID: 21980 BrickLink ID: 21980 BrickOwl ID: 397287 Peeron ID: 21980 LEGO Design ID: 21980 Element ID: 6127110 LPF2 SENSOR DETECT 2X4X1 External IDs: Rebrickable ID: 20844 LDraw ID: 20844 BrickLink ID: 20844 BrickOwl ID: 153687 Peeron ID: 20844 LEGO Design ID: 20844 Element ID: 6109228 LPF2 SENSOR TILT 2X4X1 External IDs: Rebrickable ID: 20841 LDraw ID: 20841 BrickLink ID: 20841 BrickOwl ID: 626905 Peeron ID: 20841 LEGO Design ID: 20841 Element ID: 6109223 RE: WeDo 2.0 electronics - Philippe Hurbain - 2016-05-09 Thanks, yes, I know these parts numbers for complete assemblies. What I'm trying to get is the parts numbers for each compositing elements (motor grey shell, white shell, light sensor top, light sensor bottom, etc...). RE: WeDo 2.0 electronics - Philippe Hurbain - 2016-06-03 Got tired of waiting for real part numbers, so I have started to churn out WeDo 2.0 parts on PT using uxxx names when unknown. http://www.ldraw.org/cgi-bin/ptscan.cgi?q=wedo+2 (edit) ...now completed! Enjoy! RE: WeDo 2.0 electronics - Haibing Zhang - 2016-06-05 help me! File 48\1-12con7.dat not found! http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/u9327.dat http://www.ldraw.org/library/unofficial/p/48/1-12con7.dat Not Found The requested URL was not found on this server. RE: WeDo 2.0 electronics - Philippe Hurbain - 2016-06-05 Oops, indeed! Now uploaded to PT http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=p/48/1-12con7.dat RE: WeDo 2.0 electronics - Haibing Zhang - 2016-06-05 (2016-06-05, 15:08)菲利普Hurbain Wrote: Oops, indeed! Now uploaded to PT Great! Thank you very much! RE: WeDo 2.0 electronics - Roloff de Jeu - 2016-10-03 That's so awesome Philippe! I just got me the WeDo 2.0 Core Set and hope to do after school activities with it, and it would be great to be able to 'digitally archive' the things kids have built and come up with. I've only just recently discovered non-official parts that you can add to the LCad library. I've added all of your files to the 'parts' directory, but not all are built properly in Bricksmith, like the Hub and Distance Sensor. Maybe I'm missing some files in /p/ or did I need to pit files in /s/ ? RE: WeDo 2.0 electronics - Philippe Hurbain - 2016-10-03 (2016-10-03, 10:12)Roloff de Jeu Wrote: That's so awesome Philippe! I just got me the WeDo 2.0 Core Set and hope to do after school activities with it, and it would be great to be able to 'digitally archive' the things kids have built and come up with.Glad you like them Yes, you probably miss subparts or primitives. To be sure not to miss any, I suggest that you download all unofficial parts from this page: http://www.ldraw.org/article/14.html RE: WeDo 2.0 electronics - Roloff de Jeu - 2016-10-03 Thanks Philippe, your parts look great now, it's just that a lots of other parts suddenly don't render properly.. Ouch! Reloading the parts list didn't help. I guess I need to re-install Bricksmith or something. RE: WeDo 2.0 electronics - Evgenija Zakharova - 2019-08-03 (2016-10-03, 11:12)Philippe Hurbain Wrote: Glad you like themHello! I have some problems with hub 2.0. I open in mlcad a few files, but all of them together dont give me the full picture of hub. I think its because the part 19066s01 is only right part. How can i find the full part hub 2.0& Thank you. and sorry for my english RE: WeDo 2.0 electronics - Philippe Hurbain - 2019-08-04 (2019-08-03, 20:11)Evgenija Zakharova Wrote: Hello! I have some problems with hub 2.0. I open in mlcad a few files, but all of them together dont give me the full picture of hub. I think its because the part 19066s01 is only right part. How can i find the full part hub 2.0& Thank you. and sorry for my englishI think you are missing some parts in your library... the simplest is to download all unofficial parts in one chunk here: https://www.ldraw.org/library/tracker/ |
