PDF output LPub3D changed? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: PDF output LPub3D changed? (/thread-20376.html) |
PDF output LPub3D changed? - Jaco van der Molen - 2016-02-04 Hi (Trevor), Just today I noticed there has been a change in the way LPub3D makes a PDF. Where first all text was still text and all images where individually put on the page, now one page is one whole image? Why is this? I assume you have good reasons? Can you undo this or make it optional? I often rely on the ability to manipulate individual elements in the PDF (with Acrobat Professional) and would very much like this the way it was. Thanks. Re: PDF output LPub3D changed? - Trevor Sandy - 2016-02-04 Jaco - I did not intentionally make this change but I confirm that, for some reason, the output format has changed. I'll take a look. Cheers, Re: PDF output LPub3D changed? - Jaco van der Molen - 2016-02-04 Ok, i hope you can fix it. Re: PDF output LPub3D changed? - Merlijn Wissink - 2016-02-05 +1 In basicly ALL instructions I've made, I used the pdf's ability to be edited after export. It would be very, very nice if you could bring this 'feature' back. Re: PDF output LPub3D changed? - Philippe Hurbain - 2016-02-05 Already done http://forums.ldraw.org/showthread.php?tid=20386&pid=20386#pid20386
Re: PDF output LPub3D changed? - Jaco van der Molen - 2016-02-05 Great! |
