Architecture Theme - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Official Models (https://forums.ldraw.org/forum-17.html) +--- Thread: Architecture Theme (/thread-2020.html) |
Architecture Theme - Orion Pobursky - 2011-07-25 Since I didn't actually test the upload capability, here it goes. Note that this may or may not adhere to the OMR spec. I didn't check. Edit 1 - Now OMR Spec compliant Re: 21005 - Fallingwater - Michael Heidemann - 2011-07-25 Thank for sharing this. Sadly all trees are placed 8 LDU too high. Re: 21005 - Fallingwater - Orion Pobursky - 2011-07-25 Really? I rendered this at least 10 times testing out different settings and never noticed. On a side note, I read through the OMR spec and I think it needs significant improvement... Re: 21005 - Fallingwater - Travis Cobbs - 2011-07-25 They all look fine to me. I don't see any gaps. Did Orion update the file after your post? Re: 21005 - Fallingwater - Orion Pobursky - 2011-07-25 Nope. I was at the airport so I took Mike's word for it. Re: 21005 - Fallingwater - Scott Classen - 2011-07-26 Looks fine to me viewing with Bricksmith.B) Re: 21005 - Fallingwater - Santeri Piippo - 2011-07-27 Looks fine to me as well. 21008 - Burj Kalifa - Orion Pobursky - 2011-08-01 2011 Architecture Series Re: 21008 - Burj Kalifa - Orion Pobursky - 2011-11-07 Edited to make OMR Spec compliant Re: 21008 - Burj Kalifa - Philippe Hurbain - 2011-11-07 Nitpicking: tower should use light bluish gray (71), not old gray (7)... Re: 21008 - Burj Kalifa - Orion Pobursky - 2011-11-08 Fixed. Color 7 -> 71. Blame SPAM CONTENT memory. Gotta remember Light Grey is obsolete. Re: 21005 - Fallingwater - Orion Pobursky - 2011-11-08 Updated for OMR Spec compliance. Re: 21008 - Burj Kalifa - Willy Tschager - 2011-11-08 Username missing in: 0 Author: <Author Name> [Username] w. Re: 21005 - Fallingwater - Willy Tschager - 2011-11-08 Set Number missing in: <Set Number>[ - <Optional Qualifier>] - <Individual filename> Username missing in: 0 Author: <Author Name> [Username] w. Re: 21008 - Burj Kalifa - Jude Parrill - 2011-11-14 Yeah, one of the first things I do when starting a new model is I check to see which greys were used via bricklink and/or Peeron. Then I check to make sure the greys in color-bar (in MLCad) are set correctly, so that I can use them (these are edit-able, if you didn't know). Another color that's easy to confuse is old-brown vs the new reddish-brown. I think this change happened around the same time as the grey -> bley conversion. 21011 - Brandenburg Gate - Orion Pobursky - 2011-12-05 OMR Compliant 21009 - Farnsworth House - Orion Pobursky - 2011-12-05 OMR compliant 21004 - Soloman R. Guggenheim Museum - Orion Pobursky - 2011-12-05 OMR compliant Architecture Theme - Orion Pobursky - 2011-12-05 A Topic to unify all the Architecture model Re: Architecture Theme - Philippe Hurbain - 2011-12-05 For the record, moving models to this topic made a mess with "Recent Messages"... Re: Architecture Theme - Jean-Philippe Ouellet - 2011-12-05 20 NEW MODELS!!! Philippe \Philo\" Hurbain Wrote:For the record, moving models to this topic made a mess with "Recent Messages"... Oh. Nevermind. Not new. Re: Architecture Theme - Orion Pobursky - 2011-12-06 Well 3 of them are... 21010 - Robie House - Oh-Seong KWON - 2012-01-31 This is 21010 Robie House. I put some STEP to mark a sequence of building, but it was not complete. Anyway you can enjoy this building with LDview. Special thanks to Mr. Philippe Hurbain for 99301.dat part. Enjoy Assembled by SR3D Builder 0.6.3.7 Rendered by Mega-Pov 1.2.1 Re: 21010 - Robie House - Orion Pobursky - 2012-01-31 Darn. I've been about halfway done with this for a while now... Good job Re: 21010 - Robie House - Philippe Hurbain - 2012-02-03 Looks excellent but... I have the fealing it's missing something important. What about this? Re: 21010 - Robie House - Orion Pobursky - 2012-02-03 That's cool. Any chance of getting the rest of the Theme? Re: 21010 - Robie House - Philippe Hurbain - 2012-02-03 Now that I found a reasonably matching font, should not be too hard! Or if someone else want to try... Here is the font. Re: 21010 - Robie House - Orion Pobursky - 2012-02-03 Ahh, a project to work on. I think I need to work on the website to do list more Re: 21010 - Robie House - Philippe Hurbain - 2012-02-03 OK, I couldn't resist... Here are two more: font identification - Steffen - 2012-02-04 To identify a font just by its visual appearance ("does the 'g' look so-and-so... and so on"), several databases on the web exist. They can help, even if you only have a small sample of letters. I found playing with those quite funny. Maybe you already know of those. For example: http://www.identifont.com Re: font identification - Philippe Hurbain - 2012-02-04 Yes, I did try identifont in the past - but was not SO convinced by the result. And often the best match font costs an arm... So I prefer to use font preview of some tools (here I used Corel Draw) to identify the best font already present on my system. 21012 Sydney Opera House - Oh-Seong KWON - 2012-03-07 This is a new architecture, Sydney Opera House. Enjoy KWON Re: 21008 - Burj Kalifa - Jetro de Château - 2012-03-14 Jude Wrote:Yeah, one of the first things I do when starting a new model is I check to see which greys were used via bricklink and/or Peeron. Then I check to make sure the greys in color-bar (in MLCad) are set correctly, so that I can use them (these are edit-able, if you didn't know).No, I did not and did not find a way to do so. Could you explain? Re: 21008 - Burj Kalifa - Philippe Hurbain - 2012-03-14 If you right-click on one of the color squares in the color toolbar, the color selector opens, and you can choose the color assigned to this square. Re: 21008 - Burj Kalifa - Tim Gould - 2012-03-14 It's one of the most useful 'secret' features of MLCAD I think. Was so excited when I had it pointed out to me Re: 21008 - Burj Kalifa - Philippe Hurbain - 2012-03-14 Same thing here! Re: 21008 - Burj Kalifa - Willy Tschager - 2012-03-14 You're NOT reading my tutorials by heart? http://www.holly-wood.it/mlcad/basic2-en.html Step 23: Use the color dialog also to permanently change the default colors in the Color bar. You might substitute color 7 - Light_Gray with the nowadays used color 71 - Light_Bluish_Gray or replace rare colors like Salmon or Bright_green with transparent or chrome colors. Right-clicking the color button you want to change will bring up the color dialog. Select a color as you would do for a part, okay-ing, MLCad will store the information in its settings. w. Re: 21008 - Burj Kalifa - Jetro de Château - 2012-03-15 Guilty as charged! that's what you get from biased reading. It rings a bell now, but I had completely forgotten. Any other nuggets most people gloss over or don't even think might be possible? 21002 - Empire State Building - Orion Pobursky - 2012-05-28 Should be OMR compliant. Re: 21002 - Empire State Building - Willy Tschager - 2012-05-29
w. Re: 21002 - Empire State Building - Orion Pobursky - 2012-05-30 Ok. The alias parts thing is frustrating for a number of reasons: - Not illegal per the spec - Does not affect the model in any way - No way for me to not include them in my library since I work on the Mac OSX platform so the complete.exe install file for the library is not something I can use (not that I would anyway). The .ldr extension was used since I had no submodels. Easily changed. Re: 21002 - Empire State Building - Chris Dee - 2012-05-30 Orion Pobursky Wrote:Ok. The alias parts thing is frustrating for a number of reasons: Please comment here if the suggestion to use a "=" prefix for aliases would help. Re: Architecture Theme - Reuben Pearse - 2012-06-13 I've just booked onto an event being run by RIBA (The Royal Institute of British Architects). Here's a snippet about the event: "Senior Design Manager at LEGO Simon Kent offers a unique insight to the world of LEGO and how his own training as a product designer led to having one of the best jobs in the world on the LEGO Creator design team. Simon takes you through the design processes at LEGO and uses case studies including the LEGO Creator house design, direct modular building, and world building design models. Simon will talk about how design details are added to houses and introduce the growing LEGO Architecture series." More details here I'll be at the Birmingham event in the UK on the 21st June. Let me know if you're coming! Bye for now Reuben ===================================== Download 3D Lego models and other resources from: http://www.pearse.co.uk/lego ===================================== 21013 Big Ben - Greg Teft - 2012-07-02 21014 Villa Savoye - Oh-Seong KWON - 2012-09-04 Pieces: 660 Released: 2012 Nice and cool building! Enjoy Re: 21014 Villa Savoye - Philippe Hurbain - 2012-09-04 Oh-Seong KWON Wrote:Nice and cool building!...even better when you visited the real thing 21017 Imperial Hotel - Oh-Seong KWON - 2013-03-18 I used this file for name tile. You can see this file by SR3D, MLCAD, LDview or other LDraw compatible software. Enjoy Re: 21010 - Robie House - Christoph Mierowski - 2013-12-10 I just built this model, too. And I toyed a little bit with the light.dat . The result is attached. Just use LDView to view it and mark use light.dat and replace standard light in preferences. Also a darker background is useful, so it looks nice. Re: MLCad Color Buttons Modification - Steffen - 2013-12-10 here as well! Re: MLCad Color Buttons Modification - Stephen - 2013-12-10 Arrggghhh!!! Wish I had known this when I built my LEGO Hotel. All those "tan" and "dark tan" bits were selected the "long way"! Thanks Philippe for pointing this out, and Steffen for digging up an old post - I'd probably never have discovered this otherwise. |
