LDView problem on Ubuntu 11.10 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: LDView problem on Ubuntu 11.10 (/thread-1908.html) |
LDView problem on Ubuntu 11.10 - Seth - 2011-12-02 When I try to set the LDraw dir in LDView the file dialog pops up for half a second, then LDView closes. I have reinstalled the .deb package several times and a still get this problem. What do I do? In my mind LDView is the best viewer out there I need to get it up and running. I tried using the built in function to download the parts library, but when the file dialog for that pops up, LDView still crashes. :-( Re: LDView problem on Ubuntu 11.10 - Travis Cobbs - 2011-12-02 I have a few things to say in response:
Re: LDView problem on Ubuntu 11.10 - Roland Melkert - 2011-12-02 You can download preinstalled images for both virtualbox and vmware at various places, that should help save some time. Re: LDView problem on Ubuntu 11.10 - Seth - 2011-12-04 32-bit Re: LDView problem on Ubuntu 11.10 - Seth - 2012-02-02 Uh.. Forgive me if I seem a bit naggy, but... Have you talked to the Qt guy yet? It's been a while. Re: LDView problem on Ubuntu 11.10 - Travis Cobbs - 2012-02-02 Sorry. It got lost in the shuffle. Try running LDView from the command line. I believe you'll get an error indicating which shared library/libraries is/are missing. We can go from there once I know which ones are missing. Re: LDView problem on Ubuntu 11.10 - Travis Cobbs - 2012-02-06 Please try the following package: http://www.halibut.com/~tcobbs/ldraw/private/ldview-4.1.99.2.i386.deb Please note that the above is a build done on Ubutnu 11.10 of the current LDView development source code. This means that it has new unreleased features, as well as a number of unreleased bug fixes, but it hasn't been tested as much as a normal release, so it could also have new bugs. However, since the released one isn't working for you at all, it should hopefully at least be better than that. Re: LDView problem on Ubuntu 11.10 - Seth - 2012-02-09 Thank you!! it works!!! |
