[Sticky] Parts for urgent review - Printable Version
+--- Thread: [Sticky] Parts for urgent review (/thread-1870.html)
Pages: 1 2 3 4 5 6
RE: [Sticky] Parts for urgent review - Willy Tschager - 2019-01-16
I'd like to know why we made
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/s/3039p08s01.dat
an obsolete file creating:
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/s/3039p08s02.dat
instead of simply renaming s02 to s01.
See:
http://www.ldraw.org/cgi-bin/ptscan.cgi?q=yellow%20star
RE: [Sticky] Parts for urgent review - Chris Dee - 2019-01-16
(2019-01-16, 21:23)Willy Tschager Wrote: I'd like to know why we made
See:
I don't understand either. I can rename if there is no good reason.
RE: [Sticky] Parts for urgent review - Magnus Forsberg - 2019-01-17
(2019-01-16, 22:01)Chris Dee Wrote: I don't understand either. I can rename if there is no good reason.
Does it matter if the file is called s01 or s02?
s03 is today an official file and is used in s02.
We will end up with either s02+s03 or s01+s03.
RE: [Sticky] Parts for urgent review - Willy Tschager - 2019-01-17
Fine then s01 should be deleted.
RE: [Sticky] Parts for urgent review - Chris Dee - 2019-01-17
(2019-01-17, 21:35)Willy Tschager Wrote:
(2019-01-17, 21:12)Magnus Forsberg Wrote: Does it matter if the file is called s01 or s02?
Deleted.
RE: [Sticky] Parts for urgent review - Willy Tschager - 2019-01-21
With:
13760c01.dat - Windscreen 2 x 6 x 2 with TransLightBlue Glass (Complete)
official since 2016 I'd like to know why:
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/6567c03.dat
is still on the PT?
RE: [Sticky] Parts for urgent review - Max Martin Richter - 2019-01-21
(2019-01-21, 19:51)Willy Tschager Wrote: With:
is still on the PT?
Well, there is only one set listed at bricklink, that uses such a windscreen with TrL_Blue glass as alternative - this set is 60007. According to brickset this set uses 13760 frame and 13756 glass and all pictures I found on the net show the separate frame and glass version.
I tend to say, that this part is not existing. Therefore I can not cert this part. But I'm not sure if there was a pre version of set 60007 which uses 6567c03, so I didn't held this part.
is still on the PT?
To me 13760c01 and 6567c03 are the same and therefore we should delete 6567c03.
RE: [Sticky] Parts for urgent review - Chris Dee - 2019-01-24
(2019-01-21, 21:49)Willy Tschager Wrote:
(2019-01-21, 21:42)Max Martin Richter Wrote: Well, there is only one set listed at bricklink, that uses such a windscreen with TrL_Blue glass as alternative - this set is 60007. According to brickset this set uses 13760 frame and 13756 glass and all pictures I found on the net show the separate frame and glass version.
parts/6567c03.dat has been deleted.
RE: [Sticky] Parts for urgent review - Willy Tschager - 2019-04-11
Minifig Leg Right
http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/3816b.dat
Comments?
