LDCad 1.6 suggestions/plans - Printable Version
+--- Thread: LDCad 1.6 suggestions/plans (/thread-18426.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
RE: LDCad 1.6 suggestions/plans - Willy Tschager - 2017-11-13
(2017-11-13, 20:37)David Manley Wrote:
(2017-11-13, 19:29)Roland Melkert Wrote: Why?
Roland,
I think you may find that was perhaps Willy's way of saying he doesn't like my approach in naming sub-models rather than actually advocating a return to 8.3 filenames.
David
I'm fine with your naming for what it's worth. I find it absurd that such a fine and powerful tool like LDCad requires a naming convention at all. The 10243 - Parisian Restaurant I'm currently working on is named 10243 - Ground floor - Column, 10243 -  First floor - Balcony, 10243 - Roof and I don't see why I should name them differently just because a prog cannot handle them.
RE: LDCad 1.6 suggestions/plans - Roland Melkert - 2017-11-13
(2017-11-13, 20:37)David Manley Wrote: I think you may find that was perhaps Willy's way of saying he doesn't like my approach in naming sub-models rather than actually advocating a return to 8.3 filenames.
Ah missed that Smile
(2017-11-13, 22:07)Willy Tschager Wrote: I'm fine with your naming for what it's worth. I find it absurd that such a fine and powerful tool like LDCad requires a naming convention at all. The 10243 - Parisian Restaurant I'm currently working on is named 10243 - Ground floor - Column, 10243 -  First floor - Balcony, 10243 - Roof and I don't see why I should name them differently just because a prog cannot handle them.
It still needs rules for sorting, current version uses natural sorting on description by default (so "1, 2, 10, 11, 20" without the need of a 0 prefix for single digits).
Maybe sort on keywords?, or introduce a new meta for forcing sorting?
RE: LDCad 1.6 suggestions/plans - Willy Tschager - 2017-11-14
(2017-11-13, 22:19)Roland Melkert Wrote: It still needs rules for sorting, current version uses natural sorting on description by default (so "1, 2, 10, 11, 20" without the need of a 0 prefix for single digits).
No, no, no, I'm not looking for any kind of automated sorting at all. I'd like something that leaves the order entirely to the user:
with the prog rearranging and   writing the 0 FILE statements in the chosen order.
RE: LDCad 1.6 suggestions/plans - Jaco van der Molen - 2017-11-14
No, no, no, I not looking for any kind of automated sorting at all. I'd like something that leaves the order entirely to the user:
Exactly what I was looking for.
"Sort" on hierarchy in the model file's structure, which is basically no sorting at all.
RE: LDCad 1.6 suggestions/plans - Michael Horvath - 2018-01-07
Could you please add a mode where part selection is disabled, so I don't accidentally move a part when trying to move/rotate the camera? Thanks.
RE: LDCad 1.6 suggestions/plans - Roland Melkert - 2018-01-07
(2018-01-07, 21:16)Michael Horvath Wrote: Could you please add a mode where part selection is disabled, so I don't accidentally move a part when trying to move/rotate the camera? Thanks.
This is available in the session panel (right top where you also can select nested and animation)
RE: LDCad 1.6 suggestions/plans - Philippe Hurbain - 2018-01-08
(2018-01-07, 23:15)Roland Melkert Wrote: This is available in the session panel (right top where you also can select nested and animation)
In case you wonder (like me...) it's the "View" mode!
