Gerald's Parts and Pieces Thread - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Gerald's Parts and Pieces Thread (/thread-18039.html) |
Re: Gerald's PPR > Working on 22888 Plate 4 x 8 Round Double - Gerald Lasser - 2016-03-01 I just started this part and while doing it I noticed that Part 30565, "Plate, Round Corner 4 x 4" has an issue that a stud is actually intersecting the inner portion of the wall. Should be changed sometime. Re: Gerald's PPR > Working on 22888 Plate 4 x 8 Round Double - Stephen - 2016-03-02 If I understand you correctly, it seems that 3 studs intersect the inside curved wall, and part 6003 is also affected the same way. Re: Gerald's PPR > Working on 22888 Plate 4 x 8 Round Double - Gerald Lasser - 2016-03-02 Exactly, that is the issue with them Re: Gerald's PPR > Working on 22888 Plate 4 x 8 Round Double - Magnus Forsberg - 2016-03-02 It is missing more than stud cavities. (Note that the LDD mesh is also missing them.) Re: Gerald's PPT > Sandclock (Elves) - Gerald Lasser - 2016-03-04 Set 41137 from the Elves Sets features a nice new part, a sand-clock. Unfortunately the number on the part is molded so small, I cannot read it... The part is pretty nice to do with LDPE with a combination of CSG and Pathtruder tools. I did the sketch with a hi-res sphere, however on the one hand I think it is too much as the file is now (without subfiling to e.g. a quarter) about 2500 lines long... but on the other hand a smooth look is also not bad... Edit: PS: I am still wondering how all of the pink sand fits into the bottom sphere ;-) Rollercoaster Track Pieces > 26022 - Gerald Lasser - 2018-03-02 I started the rollercoaster pieces with the short rail. PS: Strange snapshot error... RE: Rollercoaster Track Pieces > 26022 - Philippe Hurbain - 2018-03-02 Good luck Gerald ![]() RE: Rollercoaster Track Pieces > 26022 - Philippe Hurbain - 2018-04-24 (2018-03-02, 14:36)Gerald Lasser Wrote: I started the rollercoaster pieces with the short rail.Gerald, what's the status for rollercoaster part modeling? I should get them soon... RE: Rollercoaster Track Pieces > 26022 - Gerald Lasser - 2018-04-24 (2018-04-24, 14:53)Philippe Hurbain Wrote:(2018-03-02, 14:36)Gerald Lasser Wrote: I started the rollercoaster pieces with the short rail.Gerald, what's the status for rollercoaster part modeling? I should get them soon... I should finish this one in one or two days, did some heads inbetween. RE: Rollercoaster Track Pieces > 26022 - Gerald Lasser - 2018-04-26 Shall be up tonight, Cond-Lines missing. ![]() I just noticed (from pictures) that the 8L and 16L versions do not share the middle sections. So I might have done some surplus sub-filing. Currently three of them, End, Middle and End-Middle section. |
