11289 Windscreen - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: 11289 Windscreen (/thread-16904.html) |
11289 Windscreen - Tyler Clites - 2015-07-17 Looking for someone to create part 11298.
Re: 11289 Windscreen - Magnus Forsberg - 2015-07-18 I'm on it. It is present in LDD, but I don't have it. Do you have the part? Is there a particular reason for the two flat spots on the underside of the hinges? Re: 11289 Windscreen - Tyler Clites - 2015-07-18 Fantastic! Thank you so much. I do have the part. Do you need some photos? To my knowledge there is no reason for the flat spots near the hinge. Re: 11289 Windscreen - Magnus Forsberg - 2015-07-19 Could you tell me if these two corners should line up with the lilac part? Re: 11289 Windscreen - Michael Horvath - 2015-07-19 Magnus Forsberg Wrote:I'm on it. It is present in LDD, but I don't have it. I think the flat spots help keep it in the lowered and raised positions, respectively. I don't have the part though. Re: 11289 Windscreen - Tyler Clites - 2015-07-19 Yes. Those corners should line up. Re: 11289 Windscreen - Magnus Forsberg - 2015-07-20 OK, thanks. It is now at the PT. I had to move all three lines affected by those corners. Two vertical (left/right) lines and the lower horizontal line. Re: 11289 Windscreen - Magnus Forsberg - 2015-07-20 Yes, that was my first thought too. It looks more like they have made an attempt to reduce the friction, if it were to come close enough. But I can't find any part coming close enough, to work like that. Not even this contraption comes close. Used in at least 9 different models, together with this windscreen.
Re: 11289 Windscreen - Tyler Clites - 2015-07-20 Awesome! You're the best! Thank you so much! |
