SnapCAD is available! - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw Editors and Viewers (https://forums.ldraw.org/forum-11.html) +--- Thread: SnapCAD is available! (/thread-16685.html) |
SnapCAD is available! - Philippe Hurbain - 2015-06-19 SnapCAD was released officially yesterday by VEX. This is a "new" LDraw editor that targets robot building using VEX IQ parts. It is an adapted version of MLCad, and uses the parts that I modeled from VEX 3D models. See SnapCAD page here. As a side note, SnapCAD can be used for regular LDraw stuff (your just have to change default library and categories). And it does correct a few MLCad known bugs, such as the greyed-out vector rotation (you must uncheck "absolute position" to make it available). Re: SnapCAD is available! - Michael Horvath - 2015-07-15 The screenshot is very small. Do you have a bigger one? Re: SnapCAD is available! - Philippe Hurbain - 2015-07-15 There are HD video tutorials here: http://www.robotc.net/blog/2015/07/09/snapcad/ Re: SnapCAD is available! - Michael Horvath - 2015-07-17 This looks very cool. Which bugs did you fix? Re: SnapCAD is available! - Philippe Hurbain - 2015-07-17 (not me, but Michel Lachmann!) o Rotation vector enabled on relative operations o Fix undo bug for primitives o Fix undo bug for rotation point o Fix BFC statement corruption o Fix image for unknown part Re: SnapCAD is available! - Michael Horvath - 2015-07-17 Oh, I thought you were developing it. Re: SnapCAD is available! - Philippe Hurbain - 2015-07-17 Closed source... Re: SnapCAD is available! - Roland Melkert - 2015-07-17 Just wondering.. Why did he release this as snapcad and not just MLCad 3.x with some changed config files etc? Re: SnapCAD is available! - Philippe Hurbain - 2015-07-17 Because he got missionned by VEX and they needed a face lift to remove references to the somewhat competing LLEGO company... I was hoping he would release a MLCad 3.x with those bugs corrected, but nothing so far
Re: SnapCAD is available! - Michael Horvath - 2015-07-17 Not likely he'll fix the nested MPD bug...
MLCad 3.50 is available - Steffen - 2018-02-17 did you know this...?: https://www.lm-software.com/mlcad/MLCad_V3.50.zip |
