New Parts for LGEO Library - Printable Version
+--- Thread: New Parts for LGEO Library (/thread-16260.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Re: New Parts for LGEO Library - Willy Tschager - 2015-07-16
Hi Darats,
Would you please contact me at willy(dot)tschager[at]tin(dot) for the inclusion of your parts in the upcoming AIOI? Are you in contact with Owen for a seamless mix of your parts with his library and more important a harmonized LGEO.xml?
Re: New Parts for LGEO Library - Damien Roux - 2015-07-16
I've assumed it's a (dot).it
So hopefully, you got my mail.
Re: New Parts for LGEO Library - Michael Horvath - 2015-07-18
Good job Darats! The parts are very nice!
But I agree it might be better to have the studs in the STL files.
Re: New Parts for LGEO Library - Damien Roux - 2015-07-18
Why would it be better?
Update: 2015/07/18
[Image: v18-1.jpg]
6099 - Baseplate 32 x 32 Road 9-Stud Landing Pad
6099p02 - Baseplate 32 x 32 Road 9-Stud Landing Pad with Green Octogon Pattern
6099p03 - Baseplate 32 x 32 Road 9-Stud Landing Pad Type 1 (Yellow)
6099p04 - Baseplate 32 x 32 Road 9-Stud Landing Pad Type 1 (Orange)
[Image: v18-2.jpg]
6117 - Minifig Tool Chainsaw Blade
6118 - Wheel Hard-Plastic Small
6120 - Minifig Ski 4L with Hinge
6157 - Plate 2 x 2 with Wheels Holder Wide
6238a - Windscreen 4 x 4 x 1 Type 1
6269 - Minifig Goblet with Hollow Stem
6636p01 - Tile 1 x 6 with "Rockefeller" Pattern
6636p02 - Tile 1 x 6 with "Center" Pattern
6636p03 - Tile 1 x 6 with "Solomon" Pattern
6636p04 - Tile 1 x 6 with "R. Guggenheim" Pattern
6636p05 - Tile 1 x 6 with "Museum" Pattern
10201 - Bracket 1 x 2 - 1 x 4 with Rounded Corners
11211 - Brick 1 x 2 with Two Studs on One Side
12939 - Arch 1 x 6 x 2 with Thin Top
14769 - Tile 2 x 2 Round with Round Underside Stud
15068 - Slope Brick Curved 2 x 2 x 0.667
15573 - Plate 1 x 2 with Groove with 1 Center Stud, without Understud
18646 - Plate 3 x 6 Round Half with 1 x 2 Cutout
18973 - Windscreen 6 x 4 x 1.333 Curved
18980 - Plate 2 x 6 with Two Rounded Corners
30027 - Wheel Rim 8 x 8 Round Hole for Wheel Holding Pin
30027a - Wheel Rim 8 x 8 Round Hole for Wheel Holding Pin
30027b - Wheel Rim 8 x 8 Notched Hole for Wheel Holding Pin
30033 - Plate 2 x 2 with Rod Frame Octogonal
Well, I was thinking about file conversion between formats, or when/if the LDraw format is replaced with a better CAD format with true non-polygonal curves. But according to a little research I did on Wikipedia it seems I don't really know what what STL is. So never mind.
I only providing some new LGEO library high quality parts to be use in Pov Ray for renders of Ldraw files. I'm not trying to replace ldraw.
I think surface made of triangles like STL files are faster to render than part made of mathematical curves as it implies less boolean operations. Puting studs inside my stl files would take me much more time, and we would loose the ability to turn of lego logo on studs.
Maybe if the missing studs would be made also with stl files, it would be possible to write a converter that inlines everything in one file.
Re: New Parts for LGEO Library - Damien Roux - 2015-07-26
Update: 2015/07/26
[Image: v19-1.jpg]
2837 - Electric Technic Motor 9V Shaft
2837b - Electric Technic Motor 9V Top
2838 - Electric Technic Motor 9V Base
2838c01 - Electric Technic Motor 9V
2986c01 - Electric Technic Micromotor (Complete)
30377 - Minifig Mechanical Arm
30395 - Hook with Towball
30602 - Slope Brick Curved Top 2 x 2 x 1
32013 - Technic Angle Connector #1
32123a - Technic Bush 1/2 Smooth with Axle Hole Reduced
32123b - Technic Bush 1/2 Smooth with Axle Hole Semi-Reduced
32198 - Technic Gear 20 Tooth Bevel
32530 - Technic Tile 1 x 2 with Two Holes
41747 - Wedge 2 x 6 Double Right
41748 - Wedge 2 x 6 Double Left
43712 - Wedge 6 x 4 Triple Curved
43898 - Dish 3 x 3 Inverted
44375a - Dish 6 x 6 Inverted with Hollow Studs
44375b - Dish 6 x 6 Inverted with Solid Studs
47753 - Wedge 4 x 4 Triple Curved without Studs
50746 - Slope Brick 31 1 x 1 x 0.667
57515 - Technic Suspension Arm 2 x 6
57585 - Technic Bush with Three Axles
59443 - Technic Axle Joiner Inline Smooth
59900 - Cone 1 x 1 with Stop
Re: New Parts for LGEO Library - Travis Cobbs - 2015-07-27
I just wanted to point out that this thread has become nearly unusable for anyone who has their preferences set to display in threaded mode, due to be absolutely huge (requiring a ton of images to be loaded), and nested to a ridiculous degree. I would suggest creating a new thread.
Re: New Parts for LGEO Library - Damien Roux - 2015-07-27
Mmmh, you are right, I haven't thought of that.
The pictures can't even be displayed entirely in nested mode.
I can understand the nesting to be ridiculous here, but about the tons of image to display, I'm only making a pic per update, so what can I do.
@ the forum admin: is there a way to rearrange that topic and un-nest each post with a library update ?
